Stepside bed floor ideas
Old Aug 15, 2006 | 09:01 PM
f100tk77's Avatar
f100tk77
After a year of work off and on, my 77 F100 goes for paint in two weeks. Now we start to put it back together. I like the look of a wood floor but I want to do some light hauling from time to time. Has anyone given any thought to the composite wood used in deck construction? This would not look as nice as real wood but would hold up much better than real wood. I think it would look better than a metal floor.
This site has helped me through some rough spots. Thanks to everyone who posts and most of all to those of you with experience that respond. I will set up a gallery when I get it back from the painter.
Old Aug 15, 2006 | 09:03 PM
Mil1ion's Avatar
Mil1ion
Why not a roll out/down mat for when hauling things ?
It can roll up to the front out of the way and rolled out when needed
Old Aug 16, 2006 | 02:26 PM
modified79's Avatar
modified79
I had a 77stepside I replaced the wood bed in. And I replaced the original pine floor with oak and treated it with sealer and a poly-urathane coat. Also did a lot of heavy hauling with that setup. Never had any problems. But once a year you have to put a new coat of poly-urathane on it.
Old Aug 16, 2006 | 07:23 PM
dtherren's Avatar
dtherren
They also make an enamel clear coat. It is mostly used for creative wooden projects. It is darn near unscratchable. Really. I saw it on a clock made out of a slice of tree stump. It didnt scratch easily...and what a shine!!!!
I also also saw a guy had a 56 ford. He had put in a piece of oak paneling, or plywood and coated it, then put down polished aluminum or stainless strips on top of it. It looked better than the original flooring due to the woodgrain matching throughout.
I am going to convert my full size 73 to a wood floor and use hickory. Hickory is hard wood. It will dull a chain saw in a heartbeat. Stained and varnished it will (hopefully) look good. You can get that at saw mills and specialty lumber shops.
Old Aug 16, 2006 | 08:53 PM
timothy47129's Avatar
timothy47129
The worst floor I have ever seen was on my dads 1980 stepside.Someone welded a solid thich sheet of steel over the wood.I looked really good except when the wood rotted all the way out the floor bounced around and sounded like a tin can.
Tim
R H
Apr 15, 2011 09:59 PM
Greywolf
Feb 13, 2010 03:08 PM
hotrod99
Garage & Workshop
19
Apr 22, 2009 09:14 PM
46yblock
1947 and Older Ford Trucks
Jan 18, 2004 05:57 PM
jrocco
May 26, 2002 03:37 PM
