Before you guys start hammering API as the villian in the reduction of the ZDDP as a Cat destroying additive, they have nothing to do with the limitations as such. The ILSAC is the one that makes up the rules. The ILSAC is comprised of GM, Ford, DM, and JAMA (Japanese Auto Manufacturers Association) and they are given the task to make their engines complaint with Uncle Sammys emmissions criteria. Part of this is the US spec to have the engines emmissions complaint for 150,000 miles. It cannot be done with the amounts of ZDDP that was in the oils years ago. API just enforces the specs written by ILSAC. Here is a linky for your review:
The automakers may have been the ones to complain, but it still ultimately had to go through the API. Do you think they just do this stuff on a whim? I know if I was in a state where they did inspections, I wouldn't want my catylitic converter going out in 100,000 miles, or even 200,000.
But a CAT is cheaper and simpler to replace than an engine. I'd give up 50% of CAT life time for 25% gain in engine longevity in a heartbeat.
This is true, a catylitic converter is cheaper than an engine, but your numbers are arbitrary. To do it right, you'd need to compare a UOA's. And right now, it appears to me that the UOA's with SM oil in engines designed for it are going to be very hard to improve upon.
Yeah. ...and it's the nice folks in D.C. that's choosing this for all of us.
So what about an available oil additive that supplies the needed ZDDP for the old non-cat vehicles?
Alvin in AZ
ps- I bought my 1975 F150 over a 1975 F100 to side-step the gov't requirement for a "cadillac convertor"
Seems that reducing ZDDP is a way of screwing the public. Now your tightly toleranced, hotter running engine will have less wear protection. Now the rings will wear cause more gas and oil to mix, wearing down more parts and sending more polution down the pipe. Seems to me the less wear on an engine, the less ZDDP can be puffed down to the cat.
One would think so, but the UOA's dont lie. In the new vehicles it was designed for, SM seems to work well.
Now the story changes if you look at older engines with flat tappet cams. The reduced ZDDP levels can and do have an effect on those.
For the conspiracy theorist out there, consider this:
1. Who came up with the reduced ZDDP? ILSAC.
2. Who is ILSAC comprised of? Auto makers.
3. What do auto makers want you to buy? Automobiles.
4. What's the best way to create demand? Get the older vehicles with flat tappet cams off the road.
Now, it doesn't take a brain surgeon to put two and two together here...
I'd say in the automakers' defense that there's several things that are mandated by the feds (CAFE and emission, for instance); and they only need to care about their current (read: still under warranty) products.
In any case, one can get additives (i.e. Valvoline SynPower) that will add some of the needed ZDDP and some extra moly, amongst other things.
I had to replace the cats on a 150,000 mile BMW because it failed smog last year. It has always burned about a quart every 4000 or so. The owners manual calls for 15W-40 dino as the primary recommendation. I have always used Delo 400. Compression is still at new spec and the cam lobes look brand new. A set of dealer cats is about $1800, aftermarket $750.
Jim
I hope you weren't upset that your cats only lasted 150,000 miles.
Nope, 150,000 miles is considered normal life for the cats. "Universal" replacement cats wont fit under that car, its too tight under there. There are four small ones as part of a welded stainless steel headpipe assembly. The price seems reasonable, and, the state picked up $500 of it under an anti-smog program. It was $600 out-of-pocket, including diagnosis, labor and testing fees.
