oil pan
Old Aug 15, 2006 | 06:12 PM
76JDGREEN's Avatar
76JDGREEN
oil pan
I need a rear sump oil pan for my 71' 429 anyone know where i can get one?
Old Aug 15, 2006 | 06:19 PM
Mil1ion's Avatar
Mil1ion
When at the wreck'ers.... Look for E-series vans with 460's
or
check this out.
http://www.fordracingparts.com/parts...tKeyField=6128
Old Aug 15, 2006 | 06:25 PM
loveoldtrux's Avatar
loveoldtrux
Right.... my 460 uses the pan from an '83 350 e-series van
76JDGREEN's Avatar
76JDGREEN
is there a certain year?
Old Aug 15, 2006 | 06:26 PM
Mil1ion's Avatar
Mil1ion
Nope.
Also, See my earlier reply as I added something.
Old Aug 15, 2006 | 07:14 PM
banjopicker66's Avatar
banjopicker66
I used an oil pan from an '86 F-series on the 460 in my truck. It has a rear sump, so it doesn't slobber all over the crossmember any more.
If you go this route, you will need the '80s oil pump, pickup tube with special main bearing bolt to hold it in place, and the pan mounted dipstick and tube.
Well worth it in my opinion.
Old Aug 15, 2006 | 07:21 PM
Mil1ion's Avatar
Mil1ion
BP,
My though was that those trucks with the engine untouched still in them would be next to impossible to find so I didn't bother mentioning it.
But you are correct ......the thought is could he find one ?
Old Aug 15, 2006 | 08:32 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Easier to find one in a E-series van, IMO, I would have to agree.
Old Aug 15, 2006 | 09:00 PM
banjopicker66
Interesting thought, Dennis. Around here, they are becoming more common as the bodies rust out.
Old Aug 20, 2006 | 08:05 PM
77bigblock's Avatar
77bigblock
You can also order the rear sump conversion kit from Ford Racing. It comes with the pan, dipstick, oil pickup, gasket, and the new main bearing bolt. I bought it from my local Ford Dealer for around $140. It is in my 77 F250 right now and so far I am very happy. The oil didn't hit anything the first (and only, so far) I changed it.
Old Aug 20, 2006 | 08:09 PM
Mil1ion's Avatar
Mil1ion
The Ford Racing parts site I looked at stated they do NOT have one for a pickup.
The link to it is in post #2
Maybe on a lifted 4x4 it would work.
Old Aug 20, 2006 | 08:21 PM
77bigblock's Avatar
77bigblock
Ford actually sells them for the Fox body Mustangs. They do work well on the pickups, though. I actually found out about it on FTE when I was digging around in old posts.
Old Aug 20, 2006 | 09:32 PM
Mil1ion's Avatar
Mil1ion
Yes that'swhat the application says about the Oil pan ..for the Fox body,.
But it distinctly stated they don't fit Pickups
The reason they don't fit the trucks is because of the drain hole and the space between it and the cross-member ?
Like I said, Is it because yours is lifted?
Old Aug 21, 2006 | 06:47 PM
77bigblock's Avatar
77bigblock
Maybe it doesn't fit the 4x4's, but mine is two wheel drive. That is probably why it fits? All I know is that it is in my truck, and I don't have oil going all over my frame anymore, and that makes me soooo happy.
Here is the link to the thread here on FTE if you want to look at it. https://www.ford-trucks.com/forums/4...ml?=&banner=&=
Old Aug 22, 2006 | 10:16 AM
FordBoypete's Avatar
FordBoypete
FWIW,
With rear sump set up it is advisable to run a windage tray if you plan on "hammering on your 460" now & then. 385s have a tendency to "rope" oil on a hard launch. Moving the crankcase oil load to the rear makes it nearly a certainty most of the oil will rope causing oil pump to suck atmosphere.This makes for low crank/ bearing oil supply & air to Hyd' lifters & a decrease in engine power output as the roping oil slows the crank rotation.
BP66 drives like a gentleman so he does not have the above problem. I have been known to lift a wheel or two now & then. I am too familiar with the problem. You don't need to ask how I know this. . . .
FBp
