Well....i have changed out pretty much the whole cooling system on my 99 350 with approx 170k miles and now it runs great......only issue i have is that when the cruise is engaged and i start up a hill...it cuts off like some ghost is hitting the brake. Is there some fuse or lightbulb that may be out or a different issue?
look at the brake switch and see if there is a wee bit of play before the brake lights come on, same for the clutch switch if you have same. If not that, carefully pull the hub/airbag cover and look for chaffed / pinched wires going from the CC switches to the hub/clock spring.
