Remove or clean out converter?
Old Aug 15, 2006 | 12:11 PM
mxzdoo's Avatar
mxzdoo
Just curious, Have any of you removed or cleaned out your converter?
Old Aug 15, 2006 | 02:01 PM
aklim's Avatar
aklim
What are you trying to achieve? If your TC needs to be drained, I'd just flush the trans with a flusher. If your trans is toast, take TC out and toss it. The only way I'd feel safe is if they cut it open and cleaned everything out. Not worth it unless you have say a Precision Industries TC that is worth 1K
Old Aug 15, 2006 | 03:00 PM
Cuda_jim's Avatar
Cuda_jim
He's talking about the catylitic converter.
If you live in a state that requires a converter then gut it. The inspection is mainly visual, otherwise remove it.
Old Aug 15, 2006 | 08:58 PM
aklim's Avatar
aklim
I wouldn't. Even if you don't live in a state that requires it, there is nothing to say that it won't require the converter tomorrow. I'd gut it. That way if I sell it, I don't have to answer any questions.
Old Aug 15, 2006 | 09:17 PM
MRBASS's Avatar
MRBASS
Once you gut it,, I bet you can find a piece of 3 1/2" pipe and slide it right in there and tack weld the ends.
Old Aug 15, 2006 | 09:19 PM
aklim's Avatar
aklim
I'd use band clamps to hold it there so I can put it back for display purposes.
Old Aug 16, 2006 | 06:09 AM
Cuda_jim's Avatar
Cuda_jim
Don't worry about the cat, your truck is too old for emmision testing anyway.
Old Aug 16, 2006 | 07:32 AM
mxzdoo's Avatar
mxzdoo
I already gutted it out. A little persuasion, a 2lb hammer, and a 3/4in piece of pipe and she runs better with 273,000 miles than she did with 75,000. Even with the Banks Stinger II she would smoke a little when entering the freeway to get up to 70-75 mph. Now, I can't see much of anything in the side view mirror. It was very noticable right out of the gate. We don't have emissions testing here in Michigan. I was just wondering if any of you guy's had either taken your converters off or just cleaned them out. What a difference it made. I should have done that a long time ago. I'm thinking my gas milage will probably be better too.
