EOT mod
Old Aug 15, 2006 | 11:57 AM
rebelchevy02's Avatar
rebelchevy02
EOT mod
I see people adding around a 4.7k resistor inline with eot sensor on the 94-97 psd trucks, and it advances the timing, and makes the motor run better, does this hold true for the super duties? i did the 10k mod, and it seems to bring the truck to life, cant wait to get one of jodys tunes, but what about this eot mod?
Old Aug 15, 2006 | 10:20 PM
rebelchevy02
anybody? heard of this on the 99-03 series 7.3s?
Old Aug 15, 2006 | 10:43 PM
jtharvey's Avatar
jtharvey
What are you referring to as the EOT? Or, what does EOT stand for?
Old Aug 16, 2006 | 12:27 AM
wlihntr's Avatar
wlihntr
EOT = Engine Oil Temp sensor, as far as i know.
Old Aug 16, 2006 | 12:40 AM
rebelchevy02
correct EOT = engine oil temperature, i saw on the older psd trucks, were they said that depending on that reading the computer varies the timing, and if you put the right value, (around 4.7k) inline with one side, it makes the engine think the oil is cooler then it is and thus advances the timing, and it runs better, but before i go and try this in a 99+ psd i though i should ask
Old Aug 17, 2006 | 11:43 PM
rebelchevy02
so nobodys done or heard of this one?
Old Aug 18, 2006 | 12:16 AM
jtharvey's Avatar
jtharvey
Doesn't appear that anyone has done it on the PSD. Perhaps it's something to look into.
Old Aug 18, 2006 | 07:47 AM
rebelchevy02
ill have to look and see were i found it, but it was on the 94-97 psd that the mod was done to, so not sure what the difference is between those and the 99+ psd
Old Aug 18, 2006 | 04:07 PM
ryaneverk2's Avatar
ryaneverk2
I don't see how that would have an effect on timing. I'd just think that'd make the truck more likely to activate the Cold Ambient Package (raise RPM, close EBPV).
Are you thinking of the 10k mod? It uses a resistor to modify the ICP (injection control pressure) to cause the injectors to fire with a bit more oomph. Not worth much on a chipped truck as the new programming from the chip already modifies the ICP.
Here's some more/better info:
http://www.forgotton.net/mods/indexframe.html
Old Jan 22, 2009 | 06:12 PM
PaYneR's Avatar
PaYneR
bringing this post back has anyone done eot mod on sd's? im interested did a "18k" mod well didnt use 18 but similar today and i got a tad more power
Old Jan 22, 2009 | 06:16 PM
superduty4x4's Avatar
superduty4x4
Ask c00nhunterjoe in the OBS PSD forums if he's tried it on an SD... I've never heard of anyone trying it on the SD.
Old Jan 22, 2009 | 06:19 PM
PaYneR's Avatar
PaYneR
ok quick question, can you like message people or do you have to do a post reply... :S kinda new to the forums though i made this ages ago
Old Jan 22, 2009 | 06:21 PM
superduty4x4
You need at least 25 posts before you can send a PM... you're almost there
Old Jan 22, 2009 | 06:23 PM
PaYneR's Avatar
PaYneR
oh wow thanks, by the way superduty4x4 do you know alot about our 7.3's?
Old Jan 22, 2009 | 06:24 PM
superduty4x4
I would have to say no... I know a fair bit but not anywhere near what some of the other members know.
