Tie rod replacement
Old Aug 14, 2006 | 09:32 PM
Davepig's Avatar
Davepig
Tie rod replacement
Hello all. I just purchased a 1979 f-250 4x4 longbed, and have started to fix some of the mechanical problems. I tried to replace the tie rod linkage from the pitman arm to the drivers side steering knuckle (the one with the adjuster in the middle of it) and ran into a problem with the auto stores not carrying the parts. Their books did not even show my particular steering set-up and they seemed confused when I would explain it to them.
I did do a search on the forum to see if this was already talked about but came up empty-handed, unless I just did not enter the search criteria correctly.
Any information on this design and where I may be able to purchase the parts?
Old Aug 14, 2006 | 09:41 PM
460 Crew's Avatar
460 Crew
Check jeffs bronco graveyard. http://broncograveyard.com/bronco/i-..._drag_link.htm
If yours is adjustable it may be an aftermarket deal. I have and adjustable one in storage if you come up short. Also if you have a lift Skyjacker and Superlift carry a 4in drop draglinks that are adjustable.
LxMan1's Avatar
LxMan1
Welcome to the forum. Hopefully, someone will chime in soon that has run into this situation.
Did you look at 77 and 79 to see if it was a carryover?
Old Aug 14, 2006 | 10:14 PM
Davepig's Avatar
Davepig
Well, I couldn't find anything in any of the other years either. There is the possibility that the tie-rod set up is aftermarket as 460 Crew mentioned.
Currently, there is a drag link that goes from the passenger side to the drivers side with the tie-rod end on the drivers side. The pitman arm does look like a drop type for lift kits. There is nothing attached to the drivers side steering knuckle except this adjustable linkage between it and the pitman arm
From what I can gather, one of the former owners must have took the back springs off and installed them on the front, then went about making his own set of back springs to height. It's up in the air quite a bit.
It rides like a freaking rock gents, heh, but I will change that here shortly.
If it is aftermarket, what parts were removed, or better yet I should say, what am I suppose to have there? The repair manuals seem sparse on this.
Old Aug 14, 2006 | 10:34 PM
460 Crew's Avatar
460 Crew
Does your draglink drop at all like the one pictured here? http://www.ntwonline.com/acb/showdet...=1373&CATID=27 Or is it straight? The stock one is just a straight rod with 2 solid mounted balljoints. What kind of angle is that rod at right now? Should be pretty level unless they lifted it and didn't add a steering knuckle block or lift arm, or just gotten by with the drop pitman arm with a 2-4in lift.
I have pics of a stock setup on my 77.5 same as the 79 in my gallery if you want to take a look for refrence.
Old Aug 14, 2006 | 10:55 PM
Davepig's Avatar
Davepig
Originally Posted by 460 Crew
Does your draglink drop at all like the one pictured here? http://www.ntwonline.com/acb/showdetl.cfm?&DID=48&Product_ID=1373&CATID=27 Or is it straight? The stock one is just a straight rod with 2 solid mounted balljoints. What kind of angle is that rod at right now? Should be pretty level unless they lifted it and didn't add a steering knuckle block or lift arm, or just gotten by with the drop pitman arm with a 2-4in lift.
Ok, went out and looked at it in reference to what you posted. It does not have the drop bend like in the picture you posted, it is a straight arm but not one piece, it is two tie-rod ends with an adjuster in the middle. It is at a 5 degree slop or so towards the rear of the truck.
Btw, thanks for the help!
Old Aug 14, 2006 | 11:04 PM
460 Crew's Avatar
460 Crew
Sent you a PM. check in your User CP up to your top left corner.
Old Aug 15, 2006 | 09:08 AM
Red77F100's Avatar
Red77F100
I replaced all the tie rod linkage on my '77 F100 about three years ago. NAPA had all the components except the adjusting sleeve. My old one was fine, so I cleaned it and put it on my new tie rods.
The NAPA guy had to look it up in a book, and that freaked him out a little, but he found it and ordered it for me for around $300 for the lot.
AMG-SM
61
Aug 14, 2017 03:00 PM
msta999
Jun 17, 2014 08:46 PM
Yankeeblade
Jan 21, 2014 03:57 PM
eb76adam
Dec 17, 2012 10:56 PM
sdetweil
16
Aug 23, 2009 06:58 PM
