5.4 Check Engine light only when towing
Old Aug 14, 2006 | 04:50 PM
shadows4's Avatar
shadows4
I have a 1998 Expedition, 5.4. 217,000 miles. I have changed the pcv valve and the lines to it, cleaned the mass air flow sensor. I get the lean on banks 1 and 2 when I tow my travel trailer. I can clear the codes and drive the truck for weeks with no codes. When I hook up the trailer within 5 miles the check engine light comes on. I have searched the forums and haven't been able to come up with anything. Anybody have any other ideas????
John
Old Aug 14, 2006 | 07:25 PM
kspilkinton's Avatar
kspilkinton
Battery draw? Just throwing that out there. Pulling the trailer doesn't do a thing to engine performance... the only thing I can think of that has changed is your electrical.
-Kerry
Old Aug 15, 2006 | 12:46 AM
pronstar's Avatar
pronstar
How old are your 02 sensors?
Sometimes they slowly degrade, often not enough to throw a code under normal conditions but when puling you are at high engine load/large throttle openings.
I replace mine regularly, every 40K miles or so as preventive maintenance.
Old Aug 15, 2006 | 03:30 PM
shadows4's Avatar
shadows4
The O2 sensors after the cat were replaced about 20,000 miles ago. I haven't changed the front two because they look like a pain to get to. I guess I'll have to get them changed this weekend hopefully. Thanks for the replies. John
Old Aug 15, 2006 | 08:12 PM
pronstar's Avatar
pronstar
The rear ones don't really matter at all, they just tell the ECU that your cats are working.
The front ones are the ones you should be concerned with.
BTW - I've never changed my rears, only the fronts every 40K.
Old Aug 16, 2006 | 11:53 AM
Dustin_86's Avatar
Dustin_86
o2's are my guess with lean banks 1 and 2. with that code it was the o2 sensor in the manifold in my 99 zx2
Old Aug 16, 2006 | 01:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Clean the MAF - oh, wait you already did that
When was the last time the fuel filter was changed?
Old Aug 16, 2006 | 03:19 PM
shadows4's Avatar
shadows4
I have never changed the fuel filter. How would a dirty fuel filter give a lean code? Thanks for the reply krewat. John
Old Aug 16, 2006 | 03:52 PM
krewat's Avatar
krewat
By restricting the flow of fuel to the motor, causing it to run lean. Fuel-rail pressure will drop under loads. Of course, to test it, you'd have to hook up a gauge and the trailer and put it into the same situations.
My V10 sucks up a lot of gas, and by 20K miles, the fuel filter was pretty well clogged and certainly made a difference in regular driving. If you don't know it's been changed recently, do it.
Old Aug 16, 2006 | 07:49 PM
LxMan1's Avatar
LxMan1
Yep, it's cheap and not difficult and could cure all of your problems.
Old Aug 24, 2006 | 04:04 PM
raptor2020's Avatar
raptor2020
Smile Hello
I would like to say hello to everyone here and hope that we may all find answers and suggestions to the problems we may be experiencing. Hello to all!
Old Aug 26, 2006 | 12:52 AM
LxMan1's Avatar
LxMan1
Welcome to the forums Raptor
jlillie
1997 - 2003 F150
Jan 22, 2021 08:23 AM
earthbound741
2004 - 2008 F150
Apr 15, 2015 10:49 AM
jrlowscot
1997 - 2003 F150
Aug 21, 2006 11:25 PM
jlillie
1997 - 2003 F150
Nov 8, 2002 08:45 AM
