Almost Postal
Old Aug 14, 2006 | 02:39 PM
dan4147's Avatar
dan4147
Almost Postal
Around and around. This P401 EGR goes back several months. I am about to give up and go to the stealership and give up my life savings. Done everything including take it to 2 other shops with no cure, and 1 even said I needed to replace the computer. I said no....he is the only one who ever got anythning other than P401.
Does anyone have a suggestion OTHER THAN what I have already done??? Changed MAF, EGR, EGR solenoid, DPFE sensor, Removed and cleaned TB plenum, PCV and hose.....
And, could you Ford tech guys tell me what to expect when I take it to the dealer??
Thanks guys...I really like this Expy, but it is not dependable cause it will slowly shut down after leaving the cel on a while.
Old Aug 14, 2006 | 04:58 PM
FTE Herman's Avatar
FTE Herman
Are the DPFE hoses hook up to the correct tubes? One is bigger than the other and the tubes are sized accordingly. I'm sur eyou have, just checking to make sure.
The 401, that's an insufficient EGR flow? If so, the orifice in your EGR tube may be plugged. Can you remove it (from the EGR valve and exhaust manifold) and blow though it to see if it flows?
Old Aug 14, 2006 | 08:22 PM
dan4147's Avatar
dan4147
Thanks, but I checked and double checked those. It has had NO affect on the cel. Battery disconnected many times to reset. CAN THE DEALERSHIP DO A "ENGINE RUNNING PINPOINT" ON THIS ??? I'm so paranoid I don't think I would believe a "service managers" answer.
Old Aug 15, 2006 | 07:23 PM
FTE Herman's Avatar
FTE Herman
No, I'm afraid the tube has to come off. I was chasing a similar but different problem a while back with my EGR backflowing. It was during that time that I learned that the orifice exists.
The same sensor that determines insufficient exhaust gas flow is the one used by the dignostic toos, so a direct examination is necessary.
Old Aug 15, 2006 | 08:29 PM
dan4147's Avatar
dan4147
Thanks for the reply. If you're talking about the large metal tube to the EGR it is completely open. I put compressed air to it while I had the throttle body and egr off. On that "same sensor" you mentioned, what sensor is that?? I'd like to get my hands on that puppy !
Old Aug 15, 2006 | 09:16 PM
Racerguy's Avatar
Racerguy
The dealer has scan tools capable of watching what the sensors see and what the outputs are doing with the engine running. They can also use the scan tool to command the EGR to open etc to see the response.
In our shop we charge a minimum of 1 hour to do any EEC diagnosis. If it takes longer than that it will cost more. You can tell the service advisor that you're willing to spend maybe 2 hours or so and if they haven't got it solved by then to stop and phone you.
Not sure what shops charge where you are but we're $82 an hour.
By far the most common cause of a P0401 is a bad DPFE. Did you use a Ford part or an aftermarket one?
Old Aug 16, 2006 | 07:35 AM
01silvergt's Avatar
01silvergt
Just gonna throw this out there since you did not provide the first number in the code.
P0401 EGR Flow Insufficient Detected
P1401 DPFE Circuit High Input
You sure its the EGR code?
Old Aug 16, 2006 | 08:41 AM
dan4147's Avatar
dan4147
Thanks Racerguy. That's some reassurance that I like and will help me as I go to the Ford Service Dept. And, yes, I got my dpfe at Ford. That's a real good suggestion on limiting the time for them to go fishing LOL.
It occurs to me that OBDII can make everybody look bad on service.....
Old Aug 16, 2006 | 08:47 AM
dan4147's Avatar
dan4147
Yes, EGR 0401. Been working on it off and on for 6 months, mostly because it is my 2nd vehicle for rec and work. Thanks for double checking me. Scan my 1st post and tell me if you know of something else to check. I have a cheap service DVD and this forum and have gone thru all the recommendations I could find.
Old Aug 16, 2006 | 12:05 PM
01silvergt's Avatar
01silvergt
nope, you've pretty much done it all. i was just pointing out the difference between the codes. Sounds like its time to let the dealer use the scan tool.
troy676
Oct 18, 2015 01:40 PM
greenheads
Mar 17, 2015 09:47 PM
docluv5150
Aug 9, 2013 09:27 AM
Lugnut2008
Modular V8 (4.6L, 5.4L)
Nov 9, 2007 01:57 PM
indyrich
Jan 24, 2004 10:39 PM
