Sponsored by: Auxito
front end shake
Old Aug 14, 2006 | 06:54 AM
ktw10's Avatar
ktw10
front end shake
I replaced my brakes, rotors, and wheel bearings on the front of my 99 f150(XTL, 2 wheel drive, standard trans, 4 wheel abs, 4.2 eng). After getting everything installed I went for a test drive. When I reached 40 mph the stearing wheel started to shake very bad and didn't go away if I went any faster. Any ideas on what I didnt wrong?
I noticed when I removed the end nut holding the bearing and rotor to the hub that it didn't take much effort at all to loosen it. I dont know what the specs are on the torque it takes to tighting it is, but I may of put to much reinstalling it. I figured I would try that first.
Also the truck drove fine before I did this work.
Old Aug 14, 2006 | 11:57 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Did you get the wheels tightened properly? Believe it or not it happens that people forget to tighten them.
caindog110
Nov 12, 2013 08:57 PM
Blade79
Maryland Chapter
Mar 10, 2012 01:27 PM
nolascor76
2004 - 2008 F150
Dec 7, 2009 03:15 PM
dbdanny
2004 - 2008 F150
Aug 6, 2007 08:10 PM
Alphy's
16
Jul 21, 2004 09:44 PM
