Looking for Parking brake levers.
Old Aug 14, 2006 | 03:09 AM
steve442's Avatar
steve442
I am looking for a set of parking brake levers( the part that the parking brake attaches to inside the rear drums) for my 65 F-250. It has a Dana 60 rear axle, full floater. 2" rear shoes. Will levers from a 74 F-250 work?
any info would be appreciated.
Old Aug 17, 2006 | 03:36 AM
steve442's Avatar
steve442
I meant to say "The part where the parking brake cable attaches to the lever inside the rear drum"
Old Sep 30, 2006 | 02:05 AM
steve442's Avatar
steve442
Ok, can anybody PLEASE tell me where I can get parking brake parts for my 65- F250 2 wheel drive truck,I basically need everything inside the drum, my cables are good. No one has run into this????
Old Oct 1, 2006 | 12:25 AM
steve442's Avatar
steve442
65 people looking and no one has run into this???
Old Oct 1, 2006 | 12:44 AM
passengass's Avatar
passengass
I put my 65 cab and bed on 72 frame.my 65 frame wellbe a trailer no need for braks.
you mite whant to look closer to home i live in n CA. will get rearend #s in the AM
and get back to you
Old Oct 1, 2006 | 12:47 AM
steve442's Avatar
steve442
and get back to you
I have been looking everywhere, and anywhere and have had no luck, any help would be GREAT!
Thanks
Steve
Old Oct 1, 2006 | 01:11 PM
airharley's Avatar
airharley
Did you check carquest? They have all sorts of hard to find parts. I even found the rear brake soft line which no one else carried. Also the last I knew ford used bendix drum brakes on all the rearends. Worst case you will end up going on a junk yard crawl to find the right ones. Do you have the original ones?
Old Oct 1, 2006 | 07:53 PM
steve442's Avatar
steve442
I have been to all the parts stores around me, the yards around me have nothing that old anymore, so I just dont know what else to do. So I came on here to see if anyone could help. And the other problem is I have nothing to referance, all I have on the truck is shoes, the spreader bar, cable, and park brake arm are all gone.
Old Oct 1, 2006 | 08:44 PM
passengass's Avatar
passengass
going to make my 65 frame into a trailer
here are my # 5TA 2679-1 4 10
trade hole rearend
Old Oct 1, 2006 | 08:46 PM
passengass's Avatar
passengass
you live back there maybe you just want the backing plate and cables
Old Oct 1, 2006 | 11:09 PM
steve442's Avatar
steve442
If you have good ones with everything, heck yes, that would be awsome, my cables are there and are good.
Thanks, Steve
Old Oct 1, 2006 | 11:24 PM
airharley's Avatar
airharley
Well this will probably help you out then. I just did a cross referance check using kargen.com and found the brake shoes with a 2" width are the same for 65 and 74. So I would do it.
Old Oct 1, 2006 | 11:45 PM
steve442's Avatar
steve442
I did find out that the park brake setup is totally different on a 74 F250.
Old Oct 1, 2006 | 11:59 PM
steve442's Avatar
steve442
These are what I need..
Old Oct 4, 2006 | 01:25 PM
steve442's Avatar
steve442
trade hole rearend
I sent you a e-mail..
