powerstroke reliability problems
Old Aug 13, 2006 | 10:01 PM
Lynn Breckenridge's Avatar
Lynn Breckenridge
I now own an 05-6.0 F-350, srw, crewcab. This is my second Ford diesel and my first a 7.3 F-250 ran great. The ride, steering, and towing are much better in the new truck. I have two concerns, the truck has twice gone dead while driving on the freeway, no load, with the cruise control on. The first repair at the ford dealer in Calif. couldn't find any problems, they replaced the main breaker and the truck ran fine. The second time I was in Colo. driving with no load, cruise control on, and the truck went dead again. Same problem. The tech couldn't find any problem, Ford told him to replace the FICM, new main breaker and it runs fine. Has this happened to others, and what is the fix? My second issue is the turbo tube blowing off. Is there a better clamp or a fix for this?
Old Aug 16, 2006 | 06:43 AM
FloridaF250's Avatar
FloridaF250
I don't know about the truck just dying. I have an 06 F250 and that hasn't happened to me. On the turbo tube blowing off if you look through some of the older letters you'll find one on that. I can't remember how old it is. The tech folder at the top of the forum might have something also. Do your clamps have the screw tighteners on them?
Old Aug 16, 2006 | 06:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
.Moved to 6oh...
Old Aug 16, 2006 | 11:06 AM
kw5413's Avatar
kw5413
You can find much info in our 6.0 Tech Folder
https://www.ford-trucks.com/forums/3...ch-folder.html
Old Aug 16, 2006 | 11:15 AM
BowTieHatr's Avatar
BowTieHatr
if the hose is continuously blowing off, your turbo might be sticking
Old Aug 16, 2006 | 01:22 PM
huntercgr's Avatar
huntercgr
Lynn, go here to read more about your hose problem:
https://www.ford-trucks.com/forums/2...ose-clamp.html
Regarding the dieing, I'm not sure if the '05's have had wire chafing problems. Maybe someone else can chime in here about that.
Old Aug 16, 2006 | 01:32 PM
Bud in Texas's Avatar
Bud in Texas
One of my buddys has an 05 250 like mine and his did the dying thing several times. He would just be driving down the highway and it would die. Ford couldn't find anything wrong with it even with the black box monitoring it. They replaced an injector and that didn't fix it. They replaced the fuel pump and apparently that took care of it. The problem was random in nature and they couldn't get it to happen for a long time. Finally, a mechanic was using it to run an errand and got stranded. According to them, it never threw a code.
Old Aug 16, 2006 | 02:19 PM
Enomra's Avatar
Enomra
Could it be a wire chaffing issue. My 03 would do a simmilar thing right after I got it and they found that the wiring harness that runs around the steering column would short out on the sterring colunm.
Old Aug 16, 2006 | 10:37 PM
Kep4's Avatar
Kep4
Jäger
You may want to check the underhood fuses (#15 and #18) per this notification from Ford:
Various Electronic and Driveability Symptoms and Codes:
2005 F-Super Duty trucks built before 5-11-05 may exhibit various electronic-related symptoms due to loose/miss-installed fuses in the engine compartment fuse box. These symptoms may be intermittent. The fuses should be inspected to verify they are installed into the terminals in the fuse box and not along side the terminals.
Fuses--Symptoms
#9, 20 amp: Trailer turn signals inoperative
#10, 10 amp: Check Engine Light; Codes P1633, P0446
#11, 10 amp: Speedo bounce, ABS light, Cruise control inop; Codes U1900, U2023, P0500-P0503
#12, 2 amp: Cruise control inop, TBC Fault displayed, chime; Code C2803
#13, 15 amp: Day time running lamps inop
#15, 15 amp: Crank/no start, bucking, stall; Codes P2614, P2617, P1378
#17, 10 amp: A/C inop or not cooling
#18, 10 amp: Crank/no start, bucking, stall; P2614, P2617, P1378, P0611
#20, 10 amp: Trailer back up lamp inop
TSB 05-11-14
Old Aug 17, 2006 | 07:36 PM
Lynn Breckenridge
Thanks for all the input, both on the truck dying issues and the turbo tube. In reading all the sugestions it seems that the turbo tube will get oil in in it after some miles and then come off. I have also heard that the turbo can stick which over pressures the system and blows off the tube. In both cases the fix is to remove the tubes, clean and re-install. My local dealer won't change the turbo out without a stuck one. If you can show that the turbo is stuck then you get a newer one. The mystery dying could be a wire chaffing problem, but no codes thrown and no evidence found by the dealer. Fords recc. was to replace the FICM which they did. I will post more info when I find out more. Thanks for the help.
Old Aug 17, 2006 | 08:01 PM
BowTieHatr's Avatar
BowTieHatr
i have only replaced 1 ficm where as at least 8 or 9 harnessess
Old Aug 17, 2006 | 09:35 PM
Lynn Breckenridge
Which wiring harnes? Thanks
Old Aug 18, 2006 | 08:49 AM
Enomra's Avatar
Enomra
Lynn: On my truck: The tech started the truck grabbed the wiring harness under the stering column and wiggled it and the truck died instantly. He did it several times and then knew that it was the cause. Keep in mind mine is an 03 and i believe they had quite a few of the 2003's with the same problem.
Old Aug 18, 2006 | 09:12 AM
huntercgr's Avatar
huntercgr
Somewhere on these pages there are pics of possible wiring chafing locations. I was just looking at them earlier this week and of course can not find them now. Maybe someone will remember.
But, a knowledgable tech would know about them.
Old Aug 18, 2006 | 10:18 AM
kw5413's Avatar
kw5413
Ford_Doctors web site has the pics.
http://www.forddoctorsdts.com/photographs/index1.php
