New to Diesel
Old 08-14-2006, 02:14 PM
zamboni250's Avatar
zamboni250
zamboni250 is offline
New to Diesel
I have recently traded my F250 460 for a 7.3L Powerstroke and am interested in BioDiesel. I am not ready to make it myself but would like to buy it as opposed to PetroDiesel. My question is this: Can I burn B20 without any modifications to my truck? What are the negatives? Any input would be great.
Thanks in advance.
Old 08-14-2006, 03:24 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
Depending on the model year of your truck you can run B(anything) without mods.
Most PSDs were made with fuel lines, and other rubber like fuel system components, that are safe for BD. I believe the cut off for BD safe models is 1994, pre is unsafe and post is safe, I could be wrong on the year.
Bio is cleaner burning, environmentally friendly, makes your truck run quieter and smoother, and if you make your own significantly less expensive.
Old 08-15-2006, 01:54 PM
zamboni250's Avatar
zamboni250
My new to me truck is an 02 F350 4x4 CC LB. Thanks for the info. I will start reading up on making my own.
Old 08-15-2006, 08:47 PM
cookie88's Avatar
cookie88
cookie88 is offline
B20 will work fine in your truck. If you have any factory warranty left be advised that Ford only permits the use of a maximum of B5.....though I think they would have and exceptionally hard time proving you used more, if they could tell at all.
Old 08-15-2006, 09:01 PM
monsterbaby's Avatar
monsterbaby
monsterbaby is offline
The only downside to running B20 or higher is it will clean out your fuel system as bio is a great solvent. So if your going to run it carry an extra couple of fuel filters because your going to clog the first couple up, but once your fuel tank is cleaned out it will be fine. I stated down side and it is because of having to change the filters but it's also a major up side in that now your injectors, lines, pump etc are all nice and clean and working much better.
PSDiesel911
17
06-05-2008 11:37 AM
stroker roland
New Member Introductions
02-17-2008 06:20 PM
turboman24
Bio-diesel, Propane & Alternative Diesel Engine Fuels
09-24-2007 12:45 PM
captaincook
05-27-2007 10:44 PM
esmarkey
25
03-08-2006 06:19 PM
Quick Reply: New to Diesel
