Ford Truck Enthusiasts Forums
-   Bio-diesel, Propane & Alternative Diesel Engine Fuels (https://www.ford-trucks.com/forums/forum168/)
-   -   New to Diesel (https://www.ford-trucks.com/forums/517921-new-to-diesel.html)
zamboni250 08-14-2006 03:14 PM
New to Diesel
I have recently traded my F250 460 for a 7.3L Powerstroke and am interested in BioDiesel. I am not ready to make it myself but would like to buy it as opposed to PetroDiesel. My question is this: Can I burn B20 without any modifications to my truck? What are the negatives? Any input would be great.
Thanks in advance.
Phydeaux88 08-14-2006 04:24 PM
Depending on the model year of your truck you can run B(anything) without mods.
Most PSDs were made with fuel lines, and other rubber like fuel system components, that are safe for BD. I believe the cut off for BD safe models is 1994, pre is unsafe and post is safe, I could be wrong on the year.
Bio is cleaner burning, environmentally friendly, makes your truck run quieter and smoother, and if you make your own significantly less expensive.
zamboni250 08-15-2006 02:54 PM
My new to me truck is an 02 F350 4x4 CC LB. Thanks for the info. I will start reading up on making my own.
cookie88 08-15-2006 09:47 PM
B20 will work fine in your truck. If you have any factory warranty left be advised that Ford only permits the use of a maximum of B5.....though I think they would have and exceptionally hard time proving you used more, if they could tell at all.
monsterbaby 08-15-2006 10:01 PM
The only downside to running B20 or higher is it will clean out your fuel system as bio is a great solvent. So if your going to run it carry an extra couple of fuel filters because your going to clog the first couple up, but once your fuel tank is cleaned out it will be fine. I stated down side and it is because of having to change the filters but it's also a major up side in that now your injectors, lines, pump etc are all nice and clean and working much better.
© 2018 MH Sub I, LLC dba Internet Brands
