Fuel tank selector
Old Aug 12, 2006 | 05:39 PM
Ford_250's Avatar
Ford_250
Fuel tank selector
I'm redoing the dash and putting it a custom one. i want to put a toggle switch in next to the two fuel gauges to relfect which gauge it is on. Question. where can i get some sort of valve to splice into the fuel lines that will be controlled by the switch. it doesn't have to be oem. just something that can stand up to the fuel.
Old Aug 12, 2006 | 06:01 PM
fellro86's Avatar
fellro86
Do you already have dual tanks? If so, you could get a switch from a van , it goes right under the dash, and has the tanks marked out on it. As to the switch for the tanks, if you already have one, you can just use it, otherwise, you can get a factory type, or aftermarket. If you have to have return lines, you likely will have to use some kind of factory type valve, as none of the aftermarket types I know of only have 3 ports, and you would need 6.
