A/C evaporator removal procedure
Old Aug 12, 2006 | 05:15 PM
wcreay's Avatar
wcreay
Red face A/C evaporator removal procedure
1992 F150 Ford XLT 4X4 with a/c:
I would like to remove and install another evaporator coil and get my a/c working again. Could anyone tell me the procedure for it's removal? Or tell me of a manual I can buy that would show a blow up of the evaporator coil? I don't need to concern myself with recovery of the 134a refrigerant. The charge has blown out. Your help would be much appreciated. Bill
Old Aug 12, 2006 | 06:03 PM
fellro86's Avatar
fellro86
The airbox on the ouside (engine side) of the firewall unbolts, some are on the outside, and I believe there is a couple accessed from inside. It actually is pretty easy to get off, other than having to remove the inner fenderwell... The vacuum hoses disconnect behind the passenger kick panel, and the 2 bolts are readily accessible above the carpet line if I recall correctly.
Old Aug 14, 2006 | 07:26 PM
wcreay's Avatar
wcreay
Thanks a million. You have saved me a lot of time.
Old Aug 14, 2006 | 10:09 PM
fellro86's Avatar
fellro86
no problem, did that myself not too long ago...
Sous
88
Jun 12, 2022 07:36 AM
vacuumbed
52
Aug 26, 2018 04:25 PM
JB78f150
13
Sep 23, 2017 11:11 PM
mrpotatohead
Jan 17, 2017 06:23 AM
paul somlo
Escape & Escape Hybrid
Aug 4, 2015 12:59 PM
