Offroad & 4x4
another 4-wheeler question
Old 08-12-2006, 12:23 PM
4.9inline6's Avatar
4.9inline6
4.9inline6 is offline
i was watching trucks and extreme 4x4 and all that on tv a while back and on one of the shows, they mounted their front tires backwards to assist in reverse.
question: has anyone ever done this to their 4-wheeler?
does it wear the tires more?
is it worth it or will i even notice a difference?
thanks, Chris.
Old 08-12-2006, 12:33 PM
SoArkSI's Avatar
SoArkSI
SoArkSI is offline
ive been told that a directional tire (bogger, mt claw, ground hawg) mounted backwards doesnt do good on the road. I think it was somthing to do with heating up or somthing. One magazine did a write up one time about if you are running boggers or somthing directional which way you should mount your spare. and they come up with somthing about how most people offroad have flats on the passenger side because they can watch the driverside obsticales better. kinda made since. and said that if you did mount one backwards it wouldnt hurt to run it slow on the road if you HAD to. but also on extreme 4x4 the cheep jeep ( which i think you were talking about) was trailered vechicle so that might go along with running one backward since they werent driving it on the road.
Old 08-12-2006, 01:35 PM
slash31938's Avatar
slash31938
slash31938 is offline
i know the directional tires on a ATV dont do anything at all in reverse, esp in wet or uphill conditions. theres no weight on the back end to keep traction. a low gear, moving weight back, or 4 wheel drive on a ATV is all you can do.
as for the spare thing, having one tire that was mounted backwards, or even if it were bald, should get you home, or to a place you can patch/plug. this should be the case unless you are in the middle of some reallly tough trails.
Old 08-14-2006, 11:18 AM
4.9inline6's Avatar
4.9inline6
alrighty...thanks for the advice.
chris
Old 08-15-2006, 10:58 AM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is online now
Received 2,789 Likes on 1,353 Posts
Actually....my 'wheeler gets better traction in reverse (while in 4wd) than it does going forward
Old 08-15-2006, 05:02 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
Mine digs more in reverse... LOL... If you're almsot stuck and just barely moving forward, pin it in reverse, and you'll be high centered quicker than you can say high center.....
Old 08-15-2006, 06:11 PM
slash31938's Avatar
slash31938
try it in 2wd, maybe going down a slight hill. you will not move a inch, except maybe down. i had to use 4wd on my kodiak, cause i was going down a hill on the trail, couldnt go around a downed tree, and was being stupid and got too close to turn-around. in 2wd the back tires just dug.
RAGaz
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-19-2009 06:53 PM
packoo
1999 to 2016 Super Duty
20
07-10-2008 07:22 PM
V10KLZZ71S
General Automotive Discussion
29
01-30-2006 06:11 PM
mustange70
08-04-2002 08:16 PM
Chris Robinson
07-25-1999 10:54 PM
Quick Reply: another 4-wheeler question
