302 Engine Question???
Old Sep 28, 2006 | 06:37 PM
baddad457's Avatar
baddad457
Originally Posted by BuffDaddy
If it's only 1 1/2 wider I'm sure I can handle that in my plans. Height no problem. With that in mind, are carb 351W's hard to come by?? What were they in?? Last question: I can assume then that there will be a very noticible difference over the 302??,,low end? high end?? or all through the power band?? Also, big weight difference between the 302 and 351W???
Thanks, look forward to your replies.
BuffDaddy
Best 351W to look for is the 94-97 motor. It'll have the roller block and may have the cam too. If it is a roller cam it'll be an F4TE grind. Good cam for a carb. specs are 256/266 (advertised duration) lift is .420/.445 with 1.6 rockers. Add 1.7 rockers and this goes up to .445/.473. In a 5.0 with E7TE heads, a dual plane intake and 600 Holley, it runs exactly like a FI motor. Only thing it won't do is compensate for drastic altitude changes.
Old Oct 12, 2006 | 07:04 PM
Squiggy's Avatar
Squiggy
Anybody know of an exhaust system for this 96 f150? I want a whole setup from the headers to the tailpipes, I dont see a 3 inch intermediate pipe doing the trick for flow in the middle of the system. It seems way to small to flow what two 2.25 inch pipes flow in the end. You guys tell me, maybe I am wrong, but the existing y pipe and cats are garbage for flow, way to small. So what do I do. There must be a system out there that will make it sound and perform like a 5.o Mustang setup, In the end thats what I want it to sound like.
Old Oct 16, 2006 | 07:36 AM
darrin1999's Avatar
darrin1999
it will never perform like a mustang no matter what you do to it- too much weight, also it probably wont sound like a mustang because the body will resonate differently
Old Oct 19, 2006 | 07:29 PM
Squiggy's Avatar
Squiggy
I disagree, not totally but I disagree. I see a major malfunction in that statement, I only think that since it has the same block and heads, the sound should be similar. 2.5 inch on a Mustang, and 2.5 inch on a F-150 with the same components will resemble each other to some extent, I mean **** they are the same blocks.
Old Oct 19, 2006 | 09:36 PM
baddad457's Avatar
baddad457
Dual 2.25" is PLENTY for a 351 cube motor. If you want LOUD, just stick a couple of Flowmaster 40's under there.
Old Oct 20, 2006 | 01:21 PM
Peter94's Avatar
Peter94
I seriously think the nicest sound i've heard from my truck is when i put the dynomax crossflow on. I've had cherrybomb glasspacks, just a cat, the "turbo" style mufflers, etc. Plus, with the dynomax crossflow its just like putting in an x pipe too, since its a dual in, dual out with a cross in the middle. Very nice muffler.
BuffDaddy
Jul 2, 2006 07:42 PM
BuffDaddy
May 10, 2006 09:27 PM
BuffDaddy
Oil & Lubrication
Mar 23, 2006 10:58 AM
BuffDaddy
Oct 22, 2005 11:06 PM
BuffDaddy
Sep 21, 2005 10:31 PM
