Sponsored by: Auxito
What size tires?
Old Aug 11, 2006 | 02:28 PM
fordlovin's Avatar
fordlovin
What size tires?
I have a 01 F150 4x4 that I use for hunting and plowing. What size tires can it handle without any lift (it sits pretty high now.) Basically how wide can I go and what back spacing would I need? How big of tires can the stock axles handle? Are there any after market axles out there for the front?
Old Aug 11, 2006 | 02:50 PM
fordlovin's Avatar
fordlovin
Also, how small of rims can I fit around them big brakes?
Old Aug 11, 2006 | 04:53 PM
97Handshaker's Avatar
97Handshaker
You can run 285's on a 16 rim. You can only run 16 inch rims due to the size of the brake calipers.
Old Aug 11, 2006 | 10:04 PM
frazier2209's Avatar
frazier2209
you can also run 285's on a 17" wheel if that is what wheel you currently have.
