Problem with ignition switch mounting
Old Aug 11, 2006 | 11:23 AM
jaredgoodwin's Avatar
jaredgoodwin
I just bought a 78 F-250 4x4. The ignition switch flops around in the mounting hole. If I tighten the bezel all the way, it is still loose. I have looked at pictures of replacement ignition switches and they match what I have. My bezel also matches pics of replacements. Is there supposed to be a mount on the back of the dash for the switch to press into? I see there are keyways in the actual switch, is there are bracket that they go in to? Thanks
Old Aug 11, 2006 | 11:39 AM
Mil1ion's Avatar
Mil1ion
Nope, only the screw-on bezel.
Old Aug 11, 2006 | 12:27 PM
jaredgoodwin
Is there a jam nut that tightens up from behind the dash?
Old Aug 11, 2006 | 03:51 PM
jaredgoodwin
Anyone have a picture? I can't figure this out for the life of me.
Old Aug 11, 2006 | 04:52 PM
Mil1ion's Avatar
Mil1ion
There is really not clear illustration of the bezel for the switch.
It has always been push the switch thru the hole and screw the bezel onto it until the switch & bezel is tight.
Have you put the tumbler in yet ?
Old Aug 11, 2006 | 10:49 PM
jaredgoodwin
I'll take some pics of what I got tomorrow and post them up. Thanks
Old Aug 13, 2006 | 09:23 PM
jaredgoodwin
Old Aug 13, 2006 | 09:50 PM
Mil1ion's Avatar
Mil1ion
IIRC, That tumbler should be removed until the bezel has been screwed onto the switch ...holding it to the dash.
There should also be a small Notch in the dash (in the switch hole)
What is the part number of that switch to verify if it is the correct one?
Motorcraft number SW-814 is what you need.
Old Aug 13, 2006 | 10:00 PM
jaredgoodwin
D83b-11572-aa
Old Aug 13, 2006 | 10:33 PM
Ranger Gord's Avatar
Ranger Gord
I could snap some pic of mine tomorrow, it's a 79, basically the same thing.
Old Aug 13, 2006 | 10:39 PM
jaredgoodwin
That would be great!
Old Aug 13, 2006 | 10:55 PM
Mil1ion's Avatar
Mil1ion
D83b-11572-aa
That's the problem. (with the 3 changed to a letter)
The switches changed in 1978 after Vin# CAxxxx
That switch you have is an 78 switch after CAxxxx
You need the service switch number above in post # 8 or a C9AB- Number.
Old Aug 13, 2006 | 11:13 PM
jaredgoodwin
Looks like SW-814 is just the cylinder. Do you have the number for the whole switch?
Old Aug 14, 2006 | 10:19 AM
Mil1ion's Avatar
Mil1ion
That should be the switch number as it is an SW number.
Here is the Ford number.
C9AZ11572A
Old Aug 14, 2006 | 10:36 AM
jaredgoodwin
Here is what I found with that number. I am not sure how this is going to work....
http://cgi.ebay.com/ebaymotors/1967-...QQcmdZViewItem
