Now from looking at the pic, if the keyway goes into the notch in the dash, wouldn't the entire threaded portion protrude from the dash? Shouldn't the end of the switch be flush with the dash?
The problem is that behind the ignition switch there is a bracket. It has a hole for the switch to slide through with a little notch in the bottum for the ignition switch. the notch is in the bracket not the dash. look directly under and to the left a little bit of the hole in the dash for your ignition switch there should be a screw hole. the brackt screws in there and sits in the back of the dash. your ignition switch goes through the bracket, dash, then the outer screw sleeve.
It has been ages since I have been around a truck with the switch out.
That's exactly the info we were looking for and the fact that you registered to FTE to "point that out" is great
