'75 460 Transmission Options
Old Aug 10, 2006 | 03:52 PM
navyflyinggreg's Avatar
navyflyinggreg
I am looking at buying a 75 460 out of Lincoln Continental to replace my 85 300 w/ NP435 tranny. Will my NP435 bolt up to the 460 or will I need a new bellhousing? I know the 300 has the same bolt pattern as the 351w. Also, what else might I need to change for the swap? Thanks for the help!
Old Aug 10, 2006 | 06:42 PM
385seriesHemi's Avatar
385seriesHemi
They have differant bellhousings im pretty sure, the 460 has the same bolt pattern as the 351m and the 400 so
Old Aug 10, 2006 | 09:19 PM
navyflyinggreg
What about a 429 - am I going to run into the same problem?
Old Aug 10, 2006 | 09:46 PM
littleme13's Avatar
littleme13
yes the 351m 400 429 and 460 all share the same bell housing bolt pattern. the 302 351w and 300 share the same pattern if you want to keep the tranny you have.
Old Aug 10, 2006 | 11:03 PM
navyflyinggreg
I just want to get this straight, I CANNOT use the bellhousing from my 300 on the 460?
Another question, can I use the same mounting points on the frame for the 300 with the 460? I know the mounts are interchangeable between the 460 & 300, but wondering about frame location.
Thanks
Old Aug 10, 2006 | 11:05 PM
littleme13's Avatar
littleme13
no you cant use the tranny from the 300 to the 460 as far as location im not sure
Old Aug 10, 2006 | 11:14 PM
navyflyinggreg
Thanks for the info!
Old Aug 11, 2006 | 12:13 AM
littleme13's Avatar
littleme13
not a prob always glad to help out a sailor. just a quick?? for ya you enlisted or officer
Old Aug 12, 2006 | 04:08 AM
navyflyinggreg
Was both - 6 years enlisted, 3 as an O - no longer in
Old Aug 12, 2006 | 01:55 PM
littleme13's Avatar
littleme13
all i gots to so is traitor
Old Aug 13, 2006 | 04:45 PM
spide4x4's Avatar
spide4x4
Run a c-6, can't beat the tuffness!
1975-F250-4X4
Apr 10, 2016 09:34 PM
mudder460
Aug 19, 2010 01:57 AM
aco
35
Nov 4, 2001 08:41 PM
1ole4d
Aug 15, 2001 06:45 AM
jeff003
Jan 8, 2001 07:23 PM
