Chassis Mount
Old Aug 10, 2006 | 12:53 PM
BAJI26's Avatar
BAJI26
Chassis Mount
How to replace the noise making chassis driver side mount?
About how much does it cost?
Or is there another way of fixing the squeak like using a shim?
Old Aug 10, 2006 | 01:45 PM
Downriver Thunder's Avatar
Downriver Thunder
Some drill small holes and spray with silicone.
Old Aug 10, 2006 | 03:09 PM
BAJI26's Avatar
BAJI26
Can I spray it from under the truck?
I went under it and it looked like if it needed tightening or a shim when I push the chassis up. It creates a space between the metal of the mount.
Old Aug 10, 2006 | 03:42 PM
Downriver Thunder
You've got problems there if you've got a gap like that.
Old Aug 10, 2006 | 03:47 PM
buffalobob's Avatar
buffalobob
Im gonna really stretch here....how about getting away from the computer and TIGHTENING the mount??????...might just fix problem
Old Aug 10, 2006 | 03:55 PM
BAJI26's Avatar
BAJI26
LOL why you said that about the computer? LOL
I left the page open.
Old Aug 10, 2006 | 07:32 PM
BAJI26's Avatar
BAJI26
The Mounts were loose, took a breaker bar and put some muscle in it and now the squeaking noise is almost gone, 95%. Probably gotta do the back and the others. How many are in there? About 8-10?
Old Aug 12, 2006 | 12:52 AM
RACERX7775's Avatar
RACERX7775
how do you get to the bolts. from inside or under the truck? mine is making the same noise, i bought new sway bar links but did not put them in yet. $105 for the links. if its not them, i am going to return the links.
Old Aug 13, 2006 | 12:12 AM
BAJI26's Avatar
BAJI26
For the absolute front ones there are located next to the radiator, and are accessed form under the vehical.
2 more are located right behind the fender, which can be accessed under the front driver and passenger floor boards. Move the carpet and remove the rubber grommet.
2 more are under the 2nd row seats. These are going to be difficult because you might have to remove the seat or you can slit the carpet right above the bolts.
I was getting noises from the ones by the radiator which were loose and are also bad, no plans on replacing then unless I really have to ($38 each in FT. Lauderdale). Also the front passenger was really loose but the one that was the worse in noise was the one located under the driver floor board. I tightened and then sprayed some WD40 then the noise stopped completely. I will go and buy some silicon but for now I'm pleased.
Old Aug 13, 2006 | 11:33 PM
RACERX7775's Avatar
RACERX7775
thanks, i am also only getting the noise under the drivers side right under my left foot. i am going out in the morning to check it and see if it is loose.
Tom Stricklin
Nov 11, 2016 01:00 PM
mgerdau
May 3, 2016 09:05 AM
INKAHOOTZ
May 3, 2009 11:36 PM
Busguy
Oct 6, 2003 12:33 PM
RJH
Nov 14, 2002 07:07 PM
