buzzer in dash
Old Aug 13, 2006 | 05:06 PM
derherr65's Avatar
derherr65
Originally Posted by 81-F-150-Explorer
1980 to 1983 pickups, broncos have a seperate headlamp on warning buzzer. It's white. A wire (Red) from the driver door switch, and the (brown) wire from the parking lamps, goes to the buzzer. Black wire for ground. I do not believe the Green Seatbelt buzzer would work for this, because the switch for the warning light is intergrated into it, and the buzzer only stays on as long as the light does. What I'm trying to say, is the buzzer is timed. It supposed to switch off after 4 seconds, etc... Hope this helps,
Yes, excellent info. 4 seconds might actually be an advantage for me. Either I have forgotten my lights as I jump out, or I'm working on something with the door open. If I've forgotten them 4 seconds is enough of a reminder, if I'm working 4 seconds isn't so long as to be a nuisance. Assuming I can get it all set up naturally.
