Sponsored by: Real Truck
International Part #'s
Old Aug 9, 2006 | 08:47 PM
Powerkleen's Avatar
Powerkleen
Does anybody have the part # for the water pump and fan clutch on the 2000 7.3 liter. I called the local international dealer and they only had up to 1998.5 listed. I was hoping that the parts were cheaper through international as they were with the ICP, IPR, and the CMP.
Thanks for any information.
Anthony
Old Aug 9, 2006 | 08:51 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the info you need should be right in this blurb of stuff i copied from my part numbers list.
Water Pump
(Ford) F81Z-8501-BRM (engine serial no. 201680 & before)
(Ford) F81Z-8501-CRM (engine serial no. 201681 up to 98.5)
(Napa) 58-511
(Autozone) FWP-9045 (94-95 with pipe thread heater hose fitting)
(Ford) 2C3Z-8V501-BA (???)
Water Pump O-Ring Seal / Gasket
(Ford) F4TZ-8507-A
Water Pump, Upgrade to International type with Integral Filter
- 1831676C92 International water pump w/filter
- 1817958C1 30mm bolts (3)
- 1817811C1 60mm bolts (2)
- 1818693C1 110mm bolts (4)
remember the International pump has an intergral filter and MAY require a new hose.
Old Aug 10, 2006 | 05:07 PM
Powerkleen's Avatar
Powerkleen
Thanks for the numbers. I will have to look and see what I need.
Thanks
Old Aug 22, 2006 | 11:27 PM
twjull's Avatar
twjull
Is there a web site that lists all the ford and International part numbers, I am sure Ford does not want us to know this but....
Old Aug 24, 2006 | 10:56 AM
fireman28's Avatar
fireman28
Here is a rebate form for $20 off of the motocraft part.
http://ford.eprize.net/whenitfitsyou...pon_august.doc
You can click save and then print it
Old Aug 24, 2006 | 12:23 PM
PowerstrokeJunkie
twjull, this is the page i have for 7.3 Powerstroke specific parts. may help, may not.
http://www.thedwilsons.com/powerstro...t_Numbers.html
Old Aug 24, 2006 | 01:53 PM
twjull's Avatar
twjull
That is really useful information Thanks strokin_it7.3!!
Old Aug 24, 2006 | 03:42 PM
Powerkleen's Avatar
Powerkleen
Yes, Thanks to strokin_it
CaptnRed
Aug 2, 2012 12:43 PM
abranz
Nov 18, 2011 07:33 PM
aero993
Mar 27, 2010 10:23 PM
burtoby
1978 - 1996 Big Bronco
Jul 19, 2004 07:30 PM
bigf150
Mar 13, 2002 08:32 AM
