1978 - 1996 Big Bronco
what motor?
Old Aug 9, 2006 | 03:02 PM
bstt3's Avatar
bstt3
what motor?
I have a 79 bronco with a 351 mod. in it now and im going to pull it and i have two other good engines a 360 and a 460 will either one fit the same bell housing and everything else?
Thank you.
Old Aug 9, 2006 | 07:28 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Yes they both use the bigblock bellhousing and both will requier new mounts.
I would opt for the 460 as rebuilding the 360 will cost just as much but the 460 will put more power to the ground
Old Aug 9, 2006 | 08:06 PM
andym's Avatar
andym
The 360 won't fit your bellhousing, but the 460 will.
Also don't rule out building up a 400. It's basically the same motor as a 351m, but it can be built up cheaper than a 460.
Old Aug 12, 2006 | 03:01 PM
BroncoRoadKill
I always thought the Fe engines had the bigblock bellhousing.
I agree on building a 400 all you need is the crank and rods.
Or build a 600hp+ bored and stroked 460 I would talk to monsterbaby on that one.
Old Aug 12, 2006 | 05:41 PM
bstt3's Avatar
bstt3
thank you for your ideas i have the 360 and the 460 both in older F-250 trucks and both do run so im thinking the since the 460 will fit the bell housing i may go with that. any other idies?
Old Aug 13, 2006 | 11:11 AM
plowhand's Avatar
plowhand
Playing in the Dirt
If you are going to build the 460 up for big HP, while you have the engine out, have the trans rebuilt and beefed up to handle the power. It will save you time and money down the road, trust me I know. It's easier to pull the trans and engine together, just drop the trans case first. I had to raise my fan shroud becasue the 460 sat higher, about 1 1/2 inches, than the 351M. I also had to grind a small area on the right (passengers) frame to clear the exhaust (it would hit under hard torque). Everything else was pretty straight forward.
53 fatty
Florida Chapter
Mar 19, 2014 08:48 PM
darkman
Jul 30, 2002 06:57 PM
John7894
Jul 14, 2002 06:43 PM
merc460
Jun 14, 2002 09:42 PM
proeliator
Offroad & 4x4
Aug 27, 2001 10:41 AM
