Does the axle have a VSS sensor on top of the center section housing? If so, you most likely have a sterling 10.25" or 10.5" axle. If you have a whell you can test fit, you can narrow it down even further. The wheels on your truck won't fit a 10.5" axle, but they'll fit a 10.25". Different bolt pattern.
