Tie Rod end replacement?
Old Aug 9, 2006 | 11:53 AM
turboale's Avatar
turboale
So my truck is at the stealership and they are wanting $615 to install tierod ends. I can only assume that they are doing the inner and outer at that price. Am I getting totally ripped off? I heard someone quoting $700 for ball joints but that should require a lot more work if I'm not mistaken. What do you guys think?
Thanks in advance!
Old Aug 9, 2006 | 06:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by turboale
So my truck is at the stealership ........Am I getting totally ripped off?
Yes. Anytime your truck is at the dealership, you're paying more than the average.
Old Aug 10, 2006 | 10:44 AM
vettdvr's Avatar
vettdvr
Lets see now,, tie rods,, about $50 each so $100.. Alignment which you must do,, $75 so now we are at $175. Labor for tie rods, 2.5 (remember they have to fill out paperwork at $75/hr and put the truck on the rack). So we have $175+$187+$362.50.. Doesn't sound like $615 even at $75/hr. I would reallllllllly ask what they were doing (they might be doing brake inspection or some other wild thing)and or find someone else. Jim
Old Aug 10, 2006 | 09:42 PM
turboale's Avatar
turboale
They ended up replacing the whole pitman arm (I'm 4x2) which was probably a bit much but it sure does ride better. They also did do a brake check and then told me I needed a $420 brake job... that didn't even include new rotors, they just had my old ones turned. Ugh, I hate being on the road and not having a choice in the matter. Lesson learned, should have had it done before I left, but oh well... live and learn... Thanks for the replies guys!
Old Aug 11, 2006 | 07:40 AM
vettdvr's Avatar
vettdvr
Given they replaced the pitman arm and pulled all 4 wheels their price probably isn't too far off. Consider I paid $330 for just front pads, no rotors, or calipers on my wife's Mercedes at the dealer,, $420 isn't too bad if they turn the rotors and they are still within specs. I paid $330 for drilled slotted rotors and pads on all 4 wheels for my Corvette and installed them myself. So the $420 isn't too far off the mark either. Jim
Old Aug 23, 2006 | 11:21 AM
BAJI26's Avatar
BAJI26
Here in Fort Lauderdale
I purchased all 4 pads for $50 from the dealer and did the work myself.
2000 EX Limited
dferrell5
30
Jan 25, 2014 01:26 PM
Stangfire
1997 - 2003 F150
Feb 24, 2007 08:40 AM
fordberg
1947 and Older Ford Trucks
Jul 8, 2004 09:46 PM
jambroson
Apr 2, 2004 12:46 PM
knuckles69
1978 - 1996 Big Bronco
Mar 31, 2003 07:19 AM
