Engine ID
Old Aug 2, 2002 | 01:53 AM
BodieBell's Avatar
BodieBell
Engine ID
I hope someone can help me. I just bought a nicely restored 65 F100 Custom Cab in Turquoise and White. It has an engine and trans that I believe came from a 1971 LTD. The trans is a Fordomatic rebuilt by AAMCO in 1996 (receipt found in glove box) but I don't know what the engine is. It has a 2V carb and it has a Ford tag on it reading: CTF B and below that B5DD. Cast on the back of the intake manifold is: (as best as I can make out) DIAE 8425 CA. Does this givwe anyone a clue? I'd appreciate any help........
Old Aug 2, 2002 | 07:14 AM
banjopicker66's Avatar
banjopicker66
Engine ID
I think we will need a bit more than that to help you out
If you can answer these questions, we can get started.
1. Are your plugs like this: //// Or like this: //\\
2. How many bolts in each valve cover?
3. Where is the oil filled? Through a tube or a cap in the valve cover?
Old Aug 2, 2002 | 08:27 PM
BodieBell's Avatar
BodieBell
Engine ID
Thanks, John. The plugs are like this://// ; there are 6 bolts per valve cover, and the oil filler cap is on the valve cover.
Old Aug 3, 2002 | 02:12 PM
banjopicker66
Engine ID
spcpod
Jun 23, 2013 05:26 PM
Punisher56
Nov 9, 2012 11:13 PM
juice90
1983 - 2012 Ranger & B-Series
May 1, 2012 01:58 AM
Weirdjeep68
36
Feb 1, 2007 05:21 PM
SevenFive
Nov 20, 2005 08:04 PM
