Im lost Ford trans in old jeep..what is it?
Just got a 76 CJ5 with a 304. Got it for cheep!!! had a broken top plate on trans. It is stamped with a BIG ford emblem. RF E4TR 7006 AA is the ID but I can not figure out what it is. Has a chevy side t-case. Can someone tell me what this is or where I can get another top plate without geting another trans??
I've heard of people using a ford pickup Borg/Warner T-18 in your type of swap. Happen to be near Western Washington? I have an extra of these trans if that is what you have maybe I can help. Or try local wrecking yards, they usually have a pile of cores you can look through to find one that matches your top.
Good luck
Ken
Good luck
Ken
Rts
E4TR-AA = E4TR-7003-AA .. Ford Top Shift Overdrive (RTS) Ford 4 speed
E4TZ-7222-A Housing, Gear Shifter (top plate)
1980/89 Ford Light Truck Parts Catalog.
Illustration: Section 70.4, page 11
Parts list: Section 70.9A
First used in 1984 on F150/250, and U150 with 300 I-6 and 302 engines.
NOTE: Visit a dealer and look at a diagram of this transmission to make sure you get the all parts you need to repair it.
Numberdummy, give us a clue as to what "ford top shift overdrive" means. What model trans is it exactly? My bet would be a ford case T18. It would be a swap in, due to ford case and T18's mated to 304's from the factory are very rare. The only mod to make the ford T-18 work is to swap the output shaft to a shorter one, and depending on case type maybe drilling/ tapping a few holes. My brother and I are both going to swap T-18's into our pair of CJ-5's for the super low granny first gear. We are also working on a hybrid 2.46:1 dana 20 made from parts and pieces of other dana cases. The jeep one ony had 2.00:1. Good luck with the jeep. I got my 5 for $150, did you beat me?
I listed the various applications, and gave the parts listing and illustration pages, so maybe someone can look at those and tell more about what it is.
I can't scan and post because my 80/89 parts catalog is on microfiche.
Received 3,108 Likes
on
I Payed $60 to a friend (for gass) to tow it 100 miles to my house. Found it collecting rust in coosbay. Told old man that it was my dream jeep and I wanted to restor it. It was siting on blocks in his back yard with no rear end and the engin in the back so eh gave it to me. I got it home and found out the engin had water in the everything!!! After I rebilt the engin I called the ford lot in roseberg OR and gave them the vin# off the trans and they could not tell me what it was. Smart yes? Got internet a few days ago, dont know much about it, then someone from "turbobuick.com" sent me here.
This transmission is not a T-18
Can you give me a link that will have what I need or show me where to got it?
I listed the actual part you requested: E4TZ-7222-A .. Housing, gear shifter (top plate)
All you need to do, is go to your local dealer and give him the parts list number, explaining it's from the 1980-89 Ford Light Truck parts catalog. From that he can pull up the diagrams, you can pick out whatever else you need.
Note: Make no mention the trans is in a Jeep...no need to confuse the issue!
Originally Posted by handyman43358
Hmm... I'll trade ya a CJ 7 with a running straight 6, and a 100 bucks for that transmission and 304! hahaha
Is that a joke ??
I plan to put that motor and trans in my 68 jeepster, but if you are serious!!
then I'll get som pics of the engin and trans to you and let you think it over. Like I said the engin has ben rebilt but has yet to be fired.
