Sponsored by: Kumho
Radius Arm Bolts ARGH!
Old Aug 16, 2006 | 09:09 AM
51dueller's Avatar
51dueller
Good to hear you finally got it undone. My springs are the opposite, they are to strong for my truck so the tires are slanted.
Old Aug 16, 2006 | 05:29 PM
66gpw's Avatar
66gpw
well got all those nuts loose and off. Now the big bolt that goes through the radius arm and axle won't budge. Tried hammering and will not budge. Since the axle is almost off I will tomorrow unbolt it and take down to the shop and try there with the tools I have.
Does this big bolt thread into the front axle or part of the radius arm? Down at the shop I can put on the air impact and it should help. Man what a lot work to replace a worn radius arm. Yes the one on the parts truck is good. No wear spots.
Old Aug 16, 2006 | 05:35 PM
mudgepondexpress's Avatar
mudgepondexpress
I couldn't find an air wrench that would turn it myself. I used a socket and the same cheater bar and made the bolt spin. It took heating the arm with a propane torch, but it worked. Once it was able to spin it came right out.
Kenny
Coastal68
Mar 27, 2016 05:30 PM
65oldie
Oct 26, 2015 09:41 PM
MY FYN 79
Oct 18, 2015 04:13 PM
LITTLE BLACK TRUCK
27
Aug 13, 2015 02:30 PM
Greywolf
Dec 18, 2003 07:46 PM
