Horns
Old Aug 5, 2002 | 09:22 AM
jcs1966's Avatar
jcs1966
Horns
I need horns for my 1966 pickup.
the one doesnt work and they appear to be sealed so I cant get inside.
Old Aug 5, 2002 | 10:10 AM
Tedster9's Avatar
Tedster9
Horns
Didja try the WD-40 trick? Remove horn wire, and mounting hardware. Remove horn (s) Make sure you clean to shiny bright the connection at this point, that's half the circuit. Spray a couple healthy shots of WD down inside the shell, and flip it around to make sure you get some deep down in. Let it set for a cup of coffee or so, and do it again. Try a little percussive therapy (bang it around) and hook it directly up to a battery. Make sure it's pointing away from you -- it may not be your horn after, all, but the horn relay. Do you hear it click when you push the horn button?
Keep 'er between the ditches.
Old Aug 5, 2002 | 11:58 AM
44dwarf's Avatar
44dwarf
Horns
n4gnr
35
Mar 31, 2021 06:39 AM
bill2298
Jan 13, 2015 07:51 PM
Leatherneck007
Jun 26, 2014 05:43 AM
ffillah
WTB - Parts & other
Oct 3, 2012 11:31 AM
1965F100(3onthetree)
Aug 26, 2012 09:06 PM
