5.4 missing
Old Aug 7, 2006 | 09:46 PM
simplydougt's Avatar
simplydougt
5.4 missing
This is a 2003 F250 4x4 with a 5.4,Has 61,000 miles on it. Its been about to make me crazy now for about two weeks. This all started a few days after power washing the engine compartment. I stopped at a stop sign one day and felt it miss. From that day on its gotten worse. It will idle smooth and about every 20 seconds it will miss and then return to normal idle. It will miss at any speed going down the road. Does seem to clean up if I accellerate. I changed the fuel filter first, Did not help. Checked the air cleaner, Discovered the round plastic cone on the end of the filter had fallen off. It was Laying in the bottom of the filter box parcially blocking the air intake hole. Replaced filter, But did not help. A lot of the advice that Ive read on here about this problem points at the coils, boots, spark plugs, PVC hose. The check engine light is not on. Spark plugs are original. Any other advice would be greatly appreciated. I plan to start checking the mentioned items tomorrow. Is there any way to check the coils?
Old Aug 7, 2006 | 11:08 PM
pronstar's Avatar
pronstar
I'd start with EGR system then your coils.
Old Aug 8, 2006 | 08:33 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Sounds like there is moisture in a coil boot. I would pull them all, look for moisture, if there is any, get it dried out, compressed air works good, then apply dielectric grease to the boots before reinstalling. Water and COP's do not mix.
Old Aug 9, 2006 | 12:26 PM
simplydougt
Thanks for responding to my problem guys ! I will let you know how it goes !
This site is great ! Wished I would have found it a long time ago !
Old Aug 11, 2006 | 11:54 PM
mustangmike's Avatar
mustangmike
My 01 super duty is doing the exact same thing ,cant figure it out?,no codesor check engine light?
Old Aug 12, 2006 | 07:41 AM
ncranchero's Avatar
ncranchero
Agreed, moisture or cracked c.o.p. boot. Ran into the same problem after washing a 5.4 engine.
Old Aug 12, 2006 | 08:45 AM
Diesel nut's Avatar
Diesel nut
Also, look for carbon tracking on the plugs and inside the boot. Ran into this problem on a 5.4 in an F150.
dyoboiz88
Jul 15, 2018 08:32 PM
zufrieden
Dec 7, 2016 05:37 PM
97expygirl
Jan 5, 2013 10:17 PM
DerbyTracr
1997 - 2003 F150
Oct 25, 2012 08:12 AM
2001supercrewf150
Modular V8 (4.6L, 5.4L)
Mar 25, 2010 04:23 PM
