Leveling Kit 2wd screw
Old Aug 7, 2006 | 07:29 PM
F150SprCrew06's Avatar
F150SprCrew06
Question Leveling Kit 2wd screw
Hey everybody!
I just got an 06 F-150 supercrew 2wd and was wondering if it was a good idea to put a leveling kit in the front to level it up. I asked my mechanic and he said it might be a bad idea. will this hurt my front end? is it worth it? I just want to make my truck look nice and don't want to jack it up since it's just a 2wd.
I was also thinking of getting exhaust for it, I want something that sounds good, but not too loud, I kinda enjoy the quietness sometimes. any suggestions??
thanks,
Old Aug 7, 2006 | 07:43 PM
RacingJake's Avatar
RacingJake
I got a flowmaster on a 02 supercrew with the 5.4 motor. Don't know if it's a 2 or 3 chamber but it sounds good when you give it some gas but it's not loud. Even idling in the morning you can't even hear it much. It still has all the emission stuff with the 2 into one pipe too. Maybe someone knows the differance between the two size why???
Jake
Old Aug 7, 2006 | 07:52 PM
Cavtrooper06's Avatar
Cavtrooper06
Originally Posted by F150SprCrew06
Hey everybody!
thanks,
Did your mechanic state why its a bad idea? I've had mine done now for about 5,000 miles and have not had a single issue. Rides the same, turns the same, but looks a million times better.
If your looking at just a leveling kit there should be no issue.
As for the exhaust, a flowmaster 50 series would do you nicely.
Old Aug 7, 2006 | 07:56 PM
F150SprCrew06
he said it might hurt the front end. he told me to ask other people with it and see what they thought. any suggestions on a good leveling kit?
Old Aug 7, 2006 | 08:02 PM
Cavtrooper06
I recommend the autospring leveling kit (click here for the 2" or here for the 2.5") and I installed it myself. Simple to do, took about 2.5 hours without any special tools required, and all I needed afterwards was a toe-in front alignment.
There are many trucks on this forum running the autospring and I have not read a single complaint yet.
Its a quality product.
Old Aug 7, 2006 | 08:31 PM
F150SprCrew06
tires
Another question? what's the biggest size tire I can mount of the stock 17" rims?
Old Aug 8, 2006 | 11:30 AM
pjbonthebeach's Avatar
pjbonthebeach
I need to go the opposite direction. I would like to drop the back end to match the front. This would probably give me better handling as well as improved vision while backing. Any ideas?
John
2005 F150 SCrew 2WD
1946 Ford 1/2 Ton w/Flathead
Old Aug 8, 2006 | 02:04 PM
Dan F-150's Avatar
Dan F-150
Thumbs up
New guy here!
I just installed the Ground Force kit to lower the back. Now it looks right!
See this link http://www.fordmuscle.com/archives/2006/06/F150Lowering/index.php
for all the details on the installation. It took us about 2 hours.
Dan Harris
danharris@bellsouth.net
2006 F-150 XLT Supercab
Edge
Volant Intake
Old Aug 8, 2006 | 04:28 PM
Skeeter94's Avatar
Skeeter94
Hey everybody!
thanks,
I have had my leveling kit on my 04 super crew 2wd for 50,000 miles and have not had a single problem. The only thing you need to do after you put the leveling kit on is go and get an alignment.
Old Aug 8, 2006 | 05:00 PM
Abaddon's Avatar
Abaddon
Question
Quick question about the leveling kit. I have a 04 SCREW 4x4 and was wondering to level it will I need the 2" or 2.5" kit.
Thanks
Old Sep 14, 2006 | 08:43 AM
Skeeter94's Avatar
Skeeter94
Thanks
I am pretty sure a 2.5" but don't quote me on that.
Old Sep 14, 2006 | 09:31 AM
wedge88's Avatar
wedge88
I have 06' Screw 4x4 FX4 with 150"WB. I put the 2" Autospring kit on. You can view in my gallery. The 2.5" will completely level the truck but if you put any weight in the rear end or hook up a trailer that sags the rear at all your front end will be higher. With the 2" I had a 3000lb boat hooked up and it rode completely level.
Old Oct 1, 2006 | 03:32 PM
TAMU05's Avatar
TAMU05
anyone have an answe on the largest tire size for a 150 2wd? I am looking to do the same?
Old Oct 2, 2006 | 10:58 AM
Skeeter94's Avatar
Skeeter94
Yeah I have the 2.5" and tow a 3800lb boat and it sags a little.
Old Oct 2, 2006 | 11:21 AM
Skeeter94's Avatar
Skeeter94
I am running 285/70R17 Goodyear MTRs
