Mower plastic fuel tank repair?
I got a deal on one of those MTD mowers with the B&S engine on it but there was an ill fitting plastic panel on top of the motor that would hit the side of the fuel tank whenever i ran over a tree root....sure enuf a hairline crack has appeared which has left me with a small fuel leak (unless i keep the level below the crack and fill up often, which is frustrating!) Any suggestions on a product I could use to fill the crack? Need something nonreactive to gas obviously...I tried superglue gel for the heck of it, no luck.
thanks dudes
thanks dudes
What to use depends on what type of plastic you have. I once tried JB weld on a polypropylene gas tank (same plastic they make squeezable heintz bottles from) and it doesn't last; the glue doesn't "bite". Now if you have ABS you will be in luck. I think what you might want to do is try a dab of ABS and PVC glue in a few inconspicuous places (no, not on the crack yet) then after it dries see if you can pick the stuff off.
thanks dudes
thanks dudes
cjben
05-11-2012 07:21 PM
78bigunns
13
04-20-2006 02:31 PM
superrangerman2002
26
03-31-2003 09:55 PM
