Alternator good or not?
Old Sep 13, 2006 | 01:07 AM
roaky81's Avatar
roaky81
One thing I have noticed with the solid state rectifiers/alternators, if the battery voltage is too low, the alternator won't charge the battery. It's happened to me a couple of times. I guess progress is not always the best thing?
Old Sep 13, 2006 | 08:43 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by schmity
four hampster engine.
LOL, I have a new favorite saying!
Old Sep 13, 2006 | 08:56 AM
vettdvr's Avatar
vettdvr
Just $.02. I have actually had an alternator fail (as others) then rebuild by a Professional ? facility. Then it failed twice more each time they assured me it was 100% right. The 3rd failure I replaced the alternator took the defective one apart. Then I checked the regulator. I split open the case and looked at the circuit board under a magnifier and found that one of the very tiny leads had cracked. I also had the factory service manual showing the schematic. The alternator would work until the lead heated up under load. Under heat it would pull away from the circuit board and cause the alternator to go to 100 % full out put and burn out the diodes. So keep in mind you can have an alternator go bad but 99% of the time I found a battery that would charge to full voltage but not have the rerserve capacity to start. When the starter motor would engage the voltage would drop below the required necessary to turn the engine over. So in summary I would look very closely at the batteries. But then just another $.02 Jim
Myfreeford
Electrical Systems/Wiring
24
Nov 4, 2016 07:50 PM
Derekholt
Feb 22, 2015 03:01 AM
98_XLT
1997 - 2003 F150
Mar 14, 2007 04:07 PM
scroller bill
1978 - 1996 Big Bronco
Dec 14, 2006 07:39 PM
Ultramagdan
Jul 22, 2006 06:00 PM
