Check Engine Light Not Triggered?
Old Aug 22, 2006 | 09:40 PM
albung's Avatar
albung
im having similar probs but some days run good and somedays spark knock even with 93 octaine fuel have long tube headerswith the duels ran side by side! the fool i got it from welded o2 sensor in and butchered wires! either i got a bad o2 whitch i have to cut out or headers and duals lean mixture too much. what i cant figure is why one day runs like a champ then all the sudden ping ping even on a cold motor?????thinking it is pollution crap in back of heads cause i have a leak in exhaust but cant find it by changing gaskets and collector?? anyone pulled this crap off with any luck????
Old Aug 23, 2006 | 09:00 AM
soffiler's Avatar
soffiler
Originally Posted by Old_Paint
Trust me, as much as I've read on EGR's and stuff lately, I'm beginning to think about getting a job at a Ford dealership. I understand the principles quite well, and cut my mechanical molars on a re-build of a '58 Ford 8N tractor about 36 years ago, so I'm no stranger to engines. Being an electrical engineer with hybrid controls background (analog/digital), I'm no stranger to closed loop control either...
Old_Paint: another attaboy for that EGR post. Good stuff.
8N Ford tractors - hoooray! I am a Farmall and Ford tractor enthusiast myself. I've done a Cub and an 8N. But, but... the 8N was built between '48 (late '47 actually) and '52. In '53 a significant redesign (overhead valve engine, live hydraulics) became the NAA. By '55 they were producing two different sizes, the 600 series and the 800 series. Was your '58 maybe a '48?
Old Aug 23, 2006 | 09:49 AM
Old_Paint's Avatar
Old_Paint
Coulda been a '52, because I remember it had a flat-head in it. Really easy to change the plugs, which was a good thing. Seemed to need a new set every year. Also remember the PTO was driven off the pinion, which made it VERY dangerous when using a bush-hog if the drive clutch on the bush-hog seized up (which was very normal). Nice big flywheel back there. Learned to knock the tranny outta gear as soon as I pushed the clutch in to stop, and let the mower coast down. Got tired of getting pulled outta the creek. We also had a Cub Farm-All. Just had to remember to keep the left side of that one on the uphill side.
