Getting a rear axle shaft off without a special tool
I learned a handy trick for getting a rear axle shaft loose this weekend and thought I'd share it.
If you have a sticky axle shaft that doesn't want to budge, the manual calls for a special slide hammer tool that will pop the shaft loose. Just as I was ready to cave in and go try to find/buy that tool, a buddy gave me a great idea:
Attach the brake drum backwards on the axle hub and only give the lugs a few turns so that the drum has room to travel back and forth on the studs. Grab the drum with both hands and pop it towards you against the lugs. Works just like a slide hammer and the axle came out on the first try.
