My drivers side front hub wont turn now because it has a dent in it .I had a flat the truck fell of the jack that came with the truck.I now ride with a good floor jack .Is this easy to fix ?The truck fell on the rim of the flat I was mad when this happen.I cracked the plastis hub trying to turn it .What should I do ?????????How much is this going to cost me?
Hubs are easy to replace. How expensive it is will depend on your choice of hubs. But, the actual replacement is a piece of cake. There's a retaining clip around the hub that comes right off, then the hub will pull straight out.
They are pretty expensive fron the dealer (like $300) but they ae really easy to change (1 snap ring).
If you use Ebay, check there, sometimes you can get them pretty cheap used.
