View Poll Results: Do you back - probe wiring when doing electrical diagnostics?
Yes, and I don't know if it has caused future problems
7.69%
Yes, and it has never caused future problems
53.85%
Yes, and it has caused problems
7.69%
No, because I believe it will cause future wiring problems
15.38%
No, I don't know if it will cause future problems or not
0%
No, never had a need to do it
15.38%
Voters: 13. You may not vote on this poll
Back Probing Wiring
Old Aug 11, 2006 | 05:53 AM
Bob Ayers's Avatar
Bob Ayers
Originally Posted by jimdandy
I have more of a clue of what Thevenin's(including how to spell Thevenin) circuit is than you do diagnosing problems with automobile circuits. Since you have so much experience diagnosing problems with the automobile, give me an example where Thevenin would apply, and where you have used it, and where the automotive technician could benefit from it. I'm sure they would appreciate it.
If you can comprehend the above posts, a Thevinin's equivalent circuit was used to determine how much wiring series resistance would have to increase to affect the sensor voltage at the PCM, assuming the input resistance at the PCM was meg ohms. Eric had no trouble comprehending this.......I'm a little surprised you would ask for an example, since you claim to understand it!
Try studying this URL, it should help your understanding:
http://www.wd5gnr.com/basiccir.htm
And it is spelt Thevinin
You answered your self about an ignition system: "The direct current is changed to some type of waveform/pulse" you can't get a Di/Dt with DC,
which is needed to get the high voltage from an ignition coil.
Another point: "..then changed back to direct current" Simply not true with an ignition coil, or coil pack, there is no rectification off the secondary.....
That's it, I'm taking subford's approach, not wasting any more time with you!!
Old Aug 11, 2006 | 06:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Give it up, Bob.
jimdandy, I think it is time to chill~
Old Aug 11, 2006 | 07:16 AM
EPNCSU2006's Avatar
EPNCSU2006
You can get a Di/Dt with DC when the current is switched on and off and the current is flowing through a coil, which is what happens with the ignition coils. Yes this wids up as a pulsed current, but it isn't AC.
Also, with the high resistance sinks in the computer....is the signal measured before or after the sink?
I understand what you are saying, but I don't know enough about the basic hardware operation of the computer to understand how the sensor signals are processed physically.
Old Aug 11, 2006 | 07:45 AM
Bob Ayers's Avatar
Bob Ayers
Eric, we are neighbors, maybe we can get together for a technical discussion sometime!!
Old Aug 11, 2006 | 11:14 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm always up for learning new things
Old Aug 11, 2006 | 07:02 PM
jimdandy's Avatar
jimdandy
Smile
My point is that this would not be used by very few technicians diagnosing a problem with an automobile. Very few use Ohm's law to do any type of computation. They use diagnostic computers and change parts. You assume that your intelligence is so far above anyone else, that you can't/don't allow yourself just the little bit of wiggle room that you could just possibly be wrong.
I have no need to go to Bob Ayers training center. If I were ever to have a need for this type of information, I am sitting in front of a huge library.
Jean Charles Thevenin, Telegraph engineer, 1857-1926. There is an accent mark over the e in Jean and the first e in Thevenin.
"A Transformer cannot work with DC at all so this can not be true."
This is the incorrect statement from Subford. He left out some facts.
See what happens when you leave something out of a statement? I purposely left out that I was now back to talking about the DC/DC converter. I knew you would jump on it with both feet.
You have said that before. jd
Old Aug 11, 2006 | 10:01 PM
subford's Avatar
subford
The subject of the ignition coil was all ready covered in depth in this Electrical Systems/Wiring forum in a very large thread on AC, DC and transformers that I took part in. So I now only briefly talk about it and do not go into detail as I would hope that everybody has already read this thread already.
Here is the thread:
https://www.ford-trucks.com/forums/4...hlight=coil+DC
Old Aug 12, 2006 | 05:21 AM
IB Tim's Avatar
IB Tim
jimdandy, I purposely left out that I was now back to talking about the DC/DC converter. I knew you would jump on it with both feet.
Then....that is baiting, and not allowed.
Old Aug 12, 2006 | 06:09 AM
EPNCSU2006's Avatar
EPNCSU2006
Plusating DC does not equal AC, and I think that was covered in the coil thread that subford linked to...
Old Aug 13, 2006 | 05:28 PM
Bdox's Avatar
Bdox
This gets down to a language/definition problem.
As Subford points out, the "pulsating dc" is seen as a waveform, pulsating on the high side of the zero line on the scope.
Move the zero line up and it is ac.
But in fact the current flow in pulsating dc is in one direction only. The capacitor and the coil complicate things in an ignition circuit because the induced current caused by the collapsing field of the coil actually does flow the other way! So call it ac or call it dc, you have a good case either way.
Old Aug 13, 2006 | 05:37 PM
Bob Ayers's Avatar
Bob Ayers
I agree, check out this ignition waveform, and you will see the "ringing" portion of the waveform goes "negative":
http://www.automotivetestsolutions.c...oblem_idle.jpg
Old Aug 13, 2006 | 06:05 PM
Bdox's Avatar
Bdox
In the seventies, I wrote the technical manual used it the "Insta-tune" tuneup chain. They were all equipped with scopes so I had to provide the images and the explainations for all the waveforms. Points systems, no problem. This was when electronic ignition systems were just becoming common and I had to work my tail off researching all the scope patterns availble. What I learned was, the various manufacturers were all developing their own systems, but the waveforms were nearly the same even though they used different techniques to achieve them. Of course I didn't know that when I started.
Old Aug 14, 2006 | 07:58 AM
  #28
jimdandy's Avatar
jimdandy
Pulsating direct current is not ac current, no matter how you cut it.
Transformer "ringing" is an after effect of the intitial drive force, not a driving force itself.
Subford's statement was that dc current could in no way be used to drive a transformer. It was simply my opinion that his statement was wrong in the way it was worded. I think Subford is knowledgable enough to know transformers work with dc, but would the reader know this from his statement? He could have clarified, but chose not to do so. So that leaves the rest of us to do our own interpreting.
We can get into ringing and all sorts of transformer phenomina, circuit design, moving baselines, etc., but it is very dull and boring. jd
Old Aug 14, 2006 | 10:28 AM
  #29
Bdox's Avatar
Bdox
OK, let's don't call it dc or ac, let's call it GPIC for goofy primary ignition current.
Old Aug 14, 2006 | 11:21 AM
  #30
Franklin2's Avatar
Franklin2
I like that. That's what this thread needs, a little bit of humor.
