Freo change over
Old Aug 6, 2006 | 09:49 AM
MrT's Avatar
MrT
Freo change over
I have an 88 f150, the ac will not blow cold. What is involved in changing over to the new trype freon? THX!
Old Aug 6, 2006 | 04:00 PM
Nightrain's Avatar
Nightrain
From my past experiences...
I bought that R134a "cross-over" kit at Wal-Mart. Then, I just hooked it up, per the directions, and let 'er rip.
All you do is connect it to the low side, I believe, and inject the R134a just like you would the R-12. Turn your A/C on MAX and the fan on high while doing this procedure. As long as you read over the directions that come with the kit, you'll be just fine.
Always worked great for me.
I converted a 1992 Ranger with the old R-12 system, and a 1989 Buick Century with the R-12 system, also.
Hope this helps!
Nightrain
Old Aug 6, 2006 | 05:21 PM
jroehl's Avatar
jroehl
If it doesn't blow cold, you have a leak. If you have a leak, it will only get worse. Let a pro fix it. Or, just send me the several hundred dollars you'll spend on r134a that leaks out, and I'll just remind you to think cold thoughts.
Jason
Old Aug 6, 2006 | 06:06 PM
Nightrain's Avatar
Nightrain
I figured he knew he had a leak, so I just told him the process to recharge it.
Wouldn't hurt to charge it once and see how long it takes to leak down. He might not have to put but a can in it a season... You never know.
You can get those UV leak tester kits also, if you want to try and locate a leaky seal or hose.
Good luck!
Nightrain
Old Aug 8, 2006 | 02:57 AM
nascar88ford's Avatar
nascar88ford
They make some stop leak you can put in the A/C system and it seemed to fix my small leak (needed recharging about every three years). The A/C works good with the R-134a in my '87, it just takes about 3 minutes to get cool while driving. Good luck.
-Matt
oldkountryboy
61
Aug 5, 2021 10:32 PM
indiana_jones765
16
Jul 29, 2010 12:20 PM
oldranger6869
Apr 22, 2008 01:55 PM
GRUMPY_ FD
Mar 29, 2002 10:54 AM
Franklin2
Jul 13, 2001 02:47 PM
