Bad battery???????
Old Aug 5, 2006 | 11:55 PM
4xsuper's Avatar
4xsuper
Bad battery???????
Inserted key in ing.turned key and every thing went out. except for some clicking sounds and interier lights flashing. Put on charger but it said i had full charge.I did charge for @5 min. same outcome. Please advise. Thanks
Old Aug 6, 2006 | 08:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 6, 2006 | 09:38 AM
bigdaddyII's Avatar
bigdaddyII
I would start by following wires around and making sure all the connections are good. Any corrosion on the battery connections? If so clean that off, replace any wires that look corroded. This is the cheapest and easiest way to start.
Old Aug 6, 2006 | 10:16 AM
LxMan1's Avatar
LxMan1
It could be a bad battery that has voltage, but no amperage. Bad cells. If the cables check out good, I would take your battery to a local auto parts store and have it load tested.
