Testing the MAF sensor
So any ideas on how you might test one?
*beware of cleaning MAF's with electrical contact cleaner; best to use brake cleaner or carb/fi cleaner.
Electrical contact cleaners that leaves no residue is the way to go. Carb/fi cleaners I would think is to harsh on the element and I have heard people destroying there MAF’s using Carb/fi cleaners.
Pull the MAF electrical connector & make sure there is battery voltage & ground connections at the wiring harness connector.
Check the MAF elements for continuity, if it reads infinite resistance, the MAF element is open, or it's electrical connections are bad.
If all that checks out ok, plug the wiring connector back in & back probe the MAF SIG & MAF SIG RETURN wires for voltage. It should be about 0.2-1.5 volts DC at idle rpm.
Increase the engine RPM to the value you normally see on your Tach, at say 60 mph & monitor the previous voltage readings, it should increase slightly, to about 2.0 VDC at the increased RPM.
If that checks out ok, the MAF is probably ok.
You could try shuting down the engine, disconnecting the MAF, restarting he engine & see how it does, with the MAF disconnected. If it's better, then the MAF is likely still dirty, or it's out of tolerance & needs to be replaced.
Another way to check it's operation, is to monitor it's operation with a "scan tool", that'll monitor live feeds from the MAF to the computer, as you drive.
If you don't have any MAF trouble codes, saying the computer is unhappy with the MAF's inputs, it's lkely ok, imo.
Just some more thoughts on the subject.
So the real question is: how do you test a MAF?
Testing a MAF like a MAP is out of the technician’s realm of ability since installing the MAF on a flow bench and running the calibration software used by the designer is out of the question. We are relegated to monitoring output voltage versus action-reaction events that we control. Grab your scopes and a nearby Ford MAF equipped car and let’s get started. Begin by setting your DSO up for a single shot event, 500 mv/div and 100ms/div, trigger set to positive@ 1.3-l 5 volts. Next, gain access to the throttle plate because that’s where you’ll be performing the snap-rev. We don’t use the accelerator pedal due to cable stretch and carpet interference. Now, practice snapping the throttle so fast as to not cause the engine to rev-up too high. Use both hands. We have found that low voltage peaks are caused by techs that don’t make the engine take a deep breath. Monitor your test results on your DSO during this snapping of the throttle. Regardless of the engine size, a minimum of 3.5-3.7 volts should be obtained at the waveform peak.
With a few baseline tests recorded, remove the sensor and clean both wires with alcohol and a clean, new Q-tip. Retest and notice any increase in the peak and decrease in the idle voltage reading. A dirty MAF will overshoot the idle and undershoot the snap every time. If you have improved the snap, but have not reached our 3.5-3.7 volts goal, replace the sensor. Most new sensors will reach 4.0 volts. Don’t forget to check and replace if needed the MAF pigtail, as a voltage drop here will also cause inaccurate readings... SOURCE
As to my plight, I just replaced the damn thing. At 109 bucks it wasn't worth it me to fuss with it. I guess I'm gonna write this whole dang thing off as the 100k mile sensor replacement spree.
I'm still looking for a good line to use to insert the Seafoam into the intake manifold. The sticky mentioned the evaporator line but I'm still eyeballing the PCV line.
One thing that strikes me that tells me this is probably a bad sensor or part. The problem goes away for a while when I reset the computer. To me that smacks of a bad sensor. The computer gets reset, then the bad sensor slowly fills the data tables with bad input which is making the computer slowly retard the timing back the value that causes the pinging. But I'll be damned if I can figure out which one it is.
I like to use one of those metal sport inflation needles, attached to the hose that goes into the Seafoam, so that it's less likely to suck in too much Seafoam liquid, too fast & hydrolock the engine & bend something up!!!! lol
You'll probably want to consider pulling the plugs & clean them afterward, a well as change the oil & oil filter, as both will likely be loaded up with "stuff"!!!!
Just some more toughts.
BTW, did the new MAF fix things up???
We'll see what the Seafoam does for me and take it from there. I have to wait until my buddy get's back from his Guard duty so I have someone to goose the pedal when the engine starts to grumble about all that Seafoam.
Modern engines usually don't carbon up bad enough to cause a problem unless you have bad driving habits, or a problem with the engine. Many times, a hard run thru the gears peaking engine rpm will help about as much as anything. "Blowing the soot out of it" as they used to say.
Like I said, if this is such a complicated issue that I can't figure it out doing simple maintenance and replacement of suspect parts - then it's a job for the dealer.
This particular Ranger has always had intermittant pinging issues, one of the reasons I switched to 91 octane for so long. The problem went away using it. But now not even that is curing it, indicating a very real underlying problem that the 91 octane masked but needs/should have been fixed. I have two choices, let the dealer take care of it or trade it in. I've had my eye on a new Dakota for a while, but that would end my 16 year streak with Rangers.
I have to get to work reliably, and I ain't gonna fuss with it anymore. Sorry Ford.
If it's not too bad, the Seafoam may clean it up, but Chevrons Techron Consentrate, in a tank of Chevron gas would likely do as well, or maybe better, as it won't dirty up the plugs or oil & filter.
Even if you get it decarboned, you need to find out whats wrong.
It's gotta be timing, or fuel trim, seems to me & with it squaring away for a while after you pull the battery cables, seems to me that kinda points to a fuel trim, or vacuum leak problem.
With it running worse with the new MAF, makes me wonder if it was a aftermarket MAF????? If it was a aftermarket product, it's opeation response time profile, might not be the same as Fords spec for their MAF.
If you could come by, or make loan of, a good scan tool, that can read PID's, you might be able to spot the problem, by monitoring different sensors having to do with fuel trim, like the MAF, injector pulse width changes, fuel pressure, manafold vacuum, computer engine temp sensor, inlet air temperature, ect, ect. Maybe you could spot something working, but out of tolerace.
With the mileage you have on this ride, the O2 sensors would also be on the suspect list. They could be working, but lazy!!!! If you've replaced the O2 sensors with aftermarket ones, the same kinds of problems may arise as the MAF operation profile ones I mentioned.
If you have plugs of wrong design or heat range in the engine, it may protest.
If your ignition system is the "waste spark" design, you'll need the double platinum plugs. I'm not a 4 banger guy, so I'm not sure which system your 4 banger is, but your owners manual would list the proper plug for this engine.
Just more thoughts for pondeing.
