battery light
Old Aug 4, 2006 | 11:17 PM
Sundance Kid's Avatar
Sundance Kid
battery light
I have a 99 F-350 SD dually with a V-10. The battery light goes on and off during day or night.(headlights on or off).Dash meter reads that it's charging. The battery was tested and has correct charge.(no problems starting even in cold weather). The alternator checks good in the truck using a tester. I have not pulled it out and had bench tested yet. Any thoughts or ideas.
Old Aug 5, 2006 | 01:02 AM
Bdox's Avatar
Bdox
Sounds like the brushes in the alternator are failing. Cheap to fix if you are up to taking your alternator apart.
saleen065
Dec 1, 2018 08:23 AM
brian1985f150
19
Feb 7, 2017 05:52 PM
Archuriel
Oct 1, 2013 05:30 AM
bandlgeorge
16
Feb 8, 2009 01:08 PM
cornfeed
Electrical Systems/Wiring
Feb 1, 2005 04:51 PM
