Wierd A/C problem
Old Aug 16, 2006 | 08:17 PM
  #46
Greywolf's Avatar
Greywolf
Excellent! You are awesome - I can work with that and then some. Sorta reminds me of Taurus controls...
Old Aug 17, 2006 | 11:56 AM
  #47
iracekx's Avatar
iracekx
Ok I feel like a idiot now. The gauges I was using I guess were bad I borrowed another buddy's set and got readings that sound normal. Here is what I got the temp inside my garage where I did the test was 92 degrees the humidity was at 60%. I ran the vehicle for a total of 5 minutes with the A/C at full blast. The first reading I took was before the truck was ever started.
The low side read 86lbs the high side read 99lbs.
The second test was running the truck at a high RPM and my readings were as follows.
The low side would start off between 35-40lbs and as I reved it the pressure would drop to 21-22lbs and the compressor would shut off and it would climb back to 35-40lbs before the compressor would come back on.
The high side would start off between 210-220 as I reved the motor the pressure would climb to 245-260lbs then the compressor would cut off and the pressure would drop back down to 210-220lbs before the compressor would come back on.
If you let the truck sit at idle the pressure would sit at.
Low side 35
High side 225
I then shut the truck off and check the readings they dropped for a second or too then these were the readings.
Low side 63lbs
High side 74lbs
The tempreture off the center vent was reading 47-48 degrees after the truck had been running about 5-6 minutes.
I also wanted to mention one other thing I went to Oreilly and one of the guys that works their part time is a mechanic and he lloked at my truck and said it did not have a high pressure cycling switch just a low one on the dryer I just wanted to throw that in if you needed that info. Thanks again hopefully this is a enough info to diagnos the problem.
Old Aug 17, 2006 | 06:26 PM
  #48
Greywolf's Avatar
Greywolf
Copy and paste this post with all of the info just like it is, then post it in the cooling, heating, and air conditioning forum here at FTE. I think you have enough here to really interest those guys - and like I said, many of them do A/C for a living, and I know for a fact they have seen this before...
THEY WILL GIVE YOU an answer that fixes it.
Old Aug 17, 2006 | 08:39 PM
  #49
iracekx's Avatar
iracekx
I have already done that waiting for a reply.
Old Aug 17, 2006 | 09:02 PM
  #50
Greywolf's Avatar
Greywolf
GOOD ON YA!
~Wolfie
"I may not know what the answer is - but I know where I can find an answer"
Old Aug 18, 2006 | 07:52 AM
  #51
jimdandy's Avatar
jimdandy
Smile
My opinion, you are slightly low on freon, maybe half can or so. It could be something else, but I would start there if it were my truck. But, don't take my advice, follow Greywolf's. jd
Old Aug 18, 2006 | 08:15 AM
  #52
Bob Ayers's Avatar
Bob Ayers
Excellent suggestion!!
Old Aug 19, 2006 | 06:47 AM
  #53
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
OK you two, knock it off.
Last warning or suggestion, take it however you like.
Put each other on the ignore list.
I will not ask again.
UncleRedBuck
Jun 9, 2016 10:39 PM
Kountryguy
Mar 13, 2014 11:53 AM
mvedepo
2009 - 2014 F150
16
Aug 10, 2012 04:58 AM
snoschu
Jun 21, 2010 09:49 AM
runasoft
16
Jul 29, 2004 11:14 AM
