Sponsored by: Real Truck
Squeek from rear wheel
Old Aug 4, 2006 | 01:28 AM
farwhitenorth's Avatar
farwhitenorth
Question Squeek from rear wheel
I noticed a small squeek coming from the rear drivers wheel. Kind of listened to it for a few days. I checked the brakes, they are still in real good shape. Kind of decided it must be a bearing. Took it to the dealer and they can't seem to even get it to make the noise. As I was changing the oil tonight and going over things, I checked the fluid in the rear diff. It doesn't smell like the normal gear lube and is more grayish black in color. If memory serves, doesn't the gear lube from the rear end lube those bearings out at the wheels? Is it possible that those bearing are not getting lubricated the way they should? I am heading to the North Slope here in Alaska which involves about 400 miles of gravel road and there aren't too many repair shops up there. Anyone got any advice? Thanks, Eric 2001 F-350 SRW 4x4 V-10 Auto 68,000 miles.
Old Aug 4, 2006 | 02:30 PM
farwhitenorth
Rear end
How much gear lube does the rear end hold? Gonna go ahead and change it out. Eric 2001 F-350 4x4 V-10 SRW auto
Old Aug 4, 2006 | 02:33 PM
mhoefer's Avatar
mhoefer
Your book will have this quantity in it, dont forget if its an LS, you need the friction modifier as well. If ythe level is up to the check hole you should be ok. Yes, the oil in the pumpkin is what lubes those outside bearings.
Old Aug 4, 2006 | 02:52 PM
farwhitenorth
yeah, it just amazes me that ford couldn't even tell me that the fluid needed changed. guess i should have checked it before i took it to the dealer! thanks! Eric
Old Aug 4, 2006 | 03:38 PM
boxcar1974's Avatar
boxcar1974
Are you positive the squeek is a wheel bearing? I have constant squeeks that come from all four wheels. You can really hear them at slower speeds. My squeeks are due to leaf springs.
Something to consider.
I have 65K miles on my 2003 V10
Old Aug 4, 2006 | 10:21 PM
Super08's Avatar
Super08
I thought I had a problem with mine, but I tracked it down to where the emergency brake cable passes through a wire loop on the side of the frame. Squeaks like crazy. Just put some grease on it and solved the problem.
toddn78
Feb 19, 2007 09:21 PM
ATC Crazy
1997 - 2003 F150
Feb 11, 2006 11:42 AM
dblakney
May 18, 2004 08:28 PM
shakespearesdad
Oct 8, 2002 02:13 AM
Doop76
Nov 9, 2001 08:09 PM
