Sponsored by: Real Truck
2006 New Sound System
Old Aug 3, 2006 | 07:27 PM
brbsta's Avatar
brbsta
Well since the stock sound sucks put a new one into my truck with only 200 miles on it. Thought I would share some pictures since i've been looking around and have not seen any for newer 250's.
System has:
Pioneer 6800DVD 2 Dinn with IPOD and XM
Diamond Audio Front (Hex) and Rears (d6)
Pioneer Premier Shallow Mount 10" sub
JL 450/4 1000/1
Bulk pack of Dynamat, man the doors are huge.
Pictures Link: http://community.webshots.com/myphot...ecurity=oNKkol
Old Aug 3, 2006 | 07:44 PM
franlin2's Avatar
franlin2
Thumbs up
Very Nice! Did you need an install kit for the head unit or did it all come with the pioneer?
Old Aug 3, 2006 | 11:27 PM
BobbyDiesel71's Avatar
BobbyDiesel71
how hard was the tweeter install?
Old Aug 4, 2006 | 09:14 AM
Bear6522's Avatar
Bear6522
Nice setup!
My brother and I are building out a system for my 06 SD F350 similar to what was in my 04 SD F250.
I did run into an issue with the ported sub box. In my 04 SD we built a ported box with 'wings' to mount the amps. The box fit perfectly behind the set. However with my 06 SD I have the power sliding window and our 36" wide box is too big. We're building it down to 33" to clear the motor for the window.
What did you do about clearance for the window motor or do you have the power slider?
Old Aug 4, 2006 | 09:43 AM
tvsjr's Avatar
tvsjr
Brbsta-
You've done pretty much exactly what I want to do. I don't need the pimpin head up front (the Toughbook would block it anyway), but the amps/etc. are close and the sub box is perfect. Can you give us more details/a longer writeup of what you did and how you built all of it? Details on the sub box would be especially handy - I'm a computer geek, not a carpenter - fabricating something like that is beyond both my skill and my tools.
Old Aug 4, 2006 | 01:41 PM
brbsta's Avatar
brbsta
franlin2: I modded a 05 f150 install kit to fit into the f250, was not that hard.
toyota hauler: Not a hard tweeter install, took about 1/2 hour each. Had to notch out a bit of the tweeter mount to get it to clear though.
Bear6522: That box actually fit perfect between the side and the motor (I do have the slider). I did take the seat out and had to cut the little bit that come out on the back, and also dynamated all that while i was at it.
tvsjr: Yes I can when i get some time. I was going to take pictures of everything while i was doing it but i did really take the time i just wanted to get it done so i can hear it. Also you will be glad to hear that the sub box is a stock pioneer that goes with that amp. It cost me $250 for the box and the sub at the local shop. You can go check it out on there website.
Old Aug 4, 2006 | 03:15 PM
BobbyDiesel71
Originally Posted by tvsjr
Brbsta-
how do you like that particular Toughbook laptop?
is it installed in a car/truck cradle?
I am looking for a tough type laptop
what would you recomend?
bob
Old Aug 4, 2006 | 04:44 PM
LVEILLON's Avatar
LVEILLON
bob
Nice setup...I spend a lot of time in my truck so I convinced myself that I need to be comfortable and entertained also(GRIN).
ToyotaHauler..Where did you see the ToughBook in the post...I looked and didn't see it...maybe I'm overlooking it. I have a ToughBook from work. That's about all it is.."TOUGH". They are VERY expensive. I have a JottoDesk setup in my truck that I modified to remove easily when I'm not using it.
I have the Pioneer AVIC Z1 in my F250 and am wanting to add a sub, but haven't seen an enclosure that will fit like the one you have brbsta...? The only thing I've found is the JL Stealthbox for the center console, but you lose 90 percent of the storage and it's fairly pricey at $500 not to mention a sub hitting right next to you. I've installed some FoCal 5x7's and have the JL 500.1 to install when I decide on a sub setup. I'm going for sound quality. I also installed Dynamat in the doors and was very surprised how much it took. I'll do the rest of the truck soon.
Old Aug 4, 2006 | 04:50 PM
BobbyDiesel71
I have a JL audio 10 SW in an enclosure behind my drivers seat(rear jumpseat)
It goes a great job
Old Aug 4, 2006 | 06:08 PM
brbsta's Avatar
brbsta
The sub: http://www.pioneerelectronics.com/pn...969819,00.htmlThe box:
http://www.pioneerelectronics.com/pn...709443,00.html
Old Aug 4, 2006 | 06:21 PM
LVEILLON's Avatar
LVEILLON
bob
Old Aug 7, 2006 | 11:58 AM
tvsjr's Avatar
tvsjr
bob
Bob-
The Toughbook is the only way to go if you want something rugged. I'm running a CF-28 fully ruggedized unit with touch screen, but will likely grab a CF-29 here soon. Mine is attached to a Panasonic docking station, which is attached to a Havis Shields telescoping computer base. The base runs down to my equipment console (which holds all of my comms gear, light/siren controls, etc.) The laptop is set up with hazmat reference guides, access to the Internet via a Cingular aircard, access to the county's public safety network (soon), plume projection software, weather software, all sorts of fire/rescue/hazmat stuff.
Bear in mind, this isn't going to be cheap. These units run $5K-$8K new, plus the mounting hardware.
Old Aug 7, 2006 | 05:10 PM
BobbyDiesel71
would you please IM me with all info in regards to the laptop you have and are going to get(upgrades?)
I also want to see pics of the base installed in your superduty truck
thanks
bob
Old Aug 7, 2006 | 08:05 PM
tvsjr's Avatar
tvsjr
thanks
bob
I'd love to, but I don't have the time to put that together right now. Current laptop is a CF-28, P3/800, with the 13.3" touch screen. New unit will be a CF-29 or newer.
The only real pic I have handy is an in-build pic of the console:
Link
You can see the base (square tube) sticking up to the forward-right corner of the console. However, I expect my build is a bit different than yours will be.
Old Aug 7, 2006 | 09:17 PM
BobbyDiesel71
Holy Cow!!!!
