Sponsored by: Real Truck
Extreme Shaking
Old Aug 3, 2006 | 08:51 AM
Caribbean Cowgirl's Avatar
Caribbean Cowgirl
Extreme Shaking
Our 2005 F-250 has started to shake violently on the highway after hitting a moderate size bump. The entire truck shakes and bounces and is quite scary when you're doing 70 mph. Braking does not help - in fact, it seems to make it worse. The shaking finally stops after 20 seconds or so. I've brought it back to the dealer and they look at me like I'm crazy. It seems like it's getting worse now - it happens when going over smaller bumps. Any ideas? Thanks!
Old Aug 3, 2006 | 09:08 AM
tvsjr's Avatar
tvsjr
I wouldn't be driving it, and I'd be looking at front-end suspension components like ball joints, etc. for a failure. Jack the front end up and try tilting the front wheels up and down, perpendicular to the length of the truck. I suspect you'll discover some endplay on one of the front wheels...
Note that shaking is only irritating. The loss of a wheel/tire at 70mph can be at the least harrowing and at the worst fatal.
Old Aug 3, 2006 | 09:25 AM
Overkill's Avatar
Overkill
FTE *******
The source is most likely either the upper tie rod end at the pitman arm or the ball joint on the axle to which your track bar attaches. Have these checked for play.
Old Aug 3, 2006 | 09:27 AM
Pickupmanx2's Avatar
Pickupmanx2
I have heard of numerous people with this problem, one of the ladies I know here is selling her truck because of it, I would take it back to FORD before you have many miles on it and get a new or different one, once they have it, it seems to stay with the truck. I have heard of some rotating the driveshafts 180 degrees, and having good results, nobody seems to know why.
Old Aug 3, 2006 | 11:44 AM
FortyFords's Avatar
FortyFords
You need to read the post on here about death wobble
And discontinue this post.
Go to the other post and read it.
But let us know the type of options you have on your truck in the other post
thanks
Go to your dealer and tell him about TSB#05-22-1
Rich
Eric Mahoney
2009 - 2014 F150
Dec 28, 2017 06:37 PM
Bassboatman
Mar 24, 2017 06:14 PM
countryboy73703
Apr 11, 2016 09:11 AM
shuptyler
2004 - 2008 F150
23
Dec 6, 2015 07:40 PM
gaucoin
Sep 28, 2015 06:47 PM
