lower the front end
Old Aug 28, 2002 | 05:30 AM
Mike 61Ford's Avatar
Mike 61Ford
lower the front end
I have a 1961 ford unibody i would like to lower the front end. It has a straight axel on it.Would like to lower 2 to 3 inches if possible.please help out.
Old Aug 28, 2002 | 08:55 AM
cobraguy's Avatar
cobraguy
lower the front end
Mike I have a 61 uni also I wanted to lower but not slam it. I used a volare front clip and fabricated mounts for it instead of notching the frame. It bolts in just like it did in the volare. I got about 4" of drop wich looks good, plus power steering, softer independent suspension, and power disc brakes. If clipping is too much you can get a drop axle and springs that will get it anywhere you want from dragging the ground to the mile high club. Good luck, Rich.
Old Aug 29, 2002 | 03:38 AM
Zen_1963_Unibody's Avatar
Zen_1963_Unibody
lower the front end
In reply to cobraguy
Was that hard to do, putting the Volare front clip in? I've been thinking about an IFS for my '63, but I don't want a Mustang II. JUst checking outt he field, first I've heard of a Volare in a Unibody. The front ends on the beam axle F100 were definitely too high.
-Zen-
Old Aug 29, 2002 | 10:22 AM
cobraguy's Avatar
cobraguy
lower the front end
Zen, it wasn't as hard as I thought it would be at first. I did have some challenges though and had to grind off the front mounts and move them to make it all work right. If I had made the same mistake while notching the frame, wich is the normal way to install one, I'd have probably had to star over. You know measure twice cut once not measure, weld, check fit, cuss alot, get out the grinder.......
It took about 75 to 100 hours stretched out over 8 months to go from running stock to to what it is now. If I were to do it again I would look into the Aerostar or Dakota setup. The volare is nice when it's empty but put a laod in it and it will wallow like driving a waterbed. Better shocks are not available for old volares. If you have specific questions go ahead and ask. Truckfarmer is also a good person to ask as he's done a few more clips than I, and he helped me out with mine. Good luck, Rich.
Old Aug 29, 2002 | 11:29 AM
44dwarf's Avatar
44dwarf
lower the front end
Hey Cobra.
Have you looked at Pro Shock for stiffer shocks? You'll have to measure full compressed and full extended and then order the rate of dampining you need. Most OEM shocks are around a "2" rateing so I'd try a 3 or 4 rate.
44Dwarf
Old Aug 29, 2002 | 10:35 PM
cobraguy's Avatar
cobraguy
lower the front end
Hey 44dwarf I'm not racing it or anything and I don't load it up too often. I know specialty shocks can get pricey. I'd rather spend the money on other parts that are higher on the priority list.
Old Aug 30, 2002 | 04:16 AM
Zen_1963_Unibody
lower the front end
Hmmm, Aerostar front end... Now there's another front end possibility. Too bad I got rid of my old Aerostar.
Thanks for the input!
-Zen-
Old Aug 30, 2002 | 08:59 AM
cobraguy's Avatar
cobraguy
lower the front end
As I understand it the Aerostar only requires a 6" notch instead of a 22" notch to install the crossmember and it has rack&pinion. You also get to keep it all Ford wich is nice when getting a power steering to bolt to the engine. The reason I want with the volare is I got it free. If I had it to do over I'd have looked more closely at the Aerostar.
Old Aug 30, 2002 | 10:10 AM
44dwarf's Avatar
44dwarf
lower the front end
