Oh No!!!!Here We GO!!!!
Old Aug 2, 2006 | 11:10 PM
kudos383's Avatar
kudos383
06 f250 xlt 8400 miles,after hearing the whaap whaap, turbo noise and being told from my dealer tech it was just a waste gate at 3k miles,today after all the good advice i have gotton here went to another dealer,told him about it,the teck got in and went for a ride,said bring it back monday he is going to put another turbo and egr on it.Said they have a new an improved turbo for it.and he is gonna remove some coolant cause its overfilled.he says i will prob get better mpg than my current 13 to 16.BTW he said he just finished a class in the ky plant to work on the new 6.4 twin turbo,and that all he knows for now is that it inst gonna be a twin turbo now.will let you know how this works out and thanx to all who have told me the whaap whaap was not normal,you were right.
Old Aug 2, 2006 | 11:14 PM
NavyPowerstroker's Avatar
NavyPowerstroker
It is a good thing you went to a different dealer if their tech told you it was a wastegate. The 6.0 doesn't have a wastegate.
Old Aug 2, 2006 | 11:37 PM
big inch's Avatar
big inch
Yep, it sounds like you found a better place to service your truck.
Old Aug 3, 2006 | 09:14 AM
tvsjr's Avatar
tvsjr
He just completed a training class and all he knows about the motor is its turbo configuration? You may need *another* new dealer.
Old Aug 3, 2006 | 12:22 PM
raptor131's Avatar
raptor131
LMAO! i sure hope not. if that thing is twin turbo. now you''ll be replacing two instead of one. i need to buy stock in that turbo manufacturer. as they will be selling like hot cakes
Old Aug 3, 2006 | 12:59 PM
ag-ford-4x4's Avatar
ag-ford-4x4
id be more concerned with the fact they are replacing the turbo strictly based on the flutter. I dont see a problem.
Old Aug 4, 2006 | 01:14 AM
kudos383's Avatar
kudos383
I ask him about the twin turbo,he said it's not gonna be a twin t. i didnt ask him anything else about the twin turbo.and as far as changein my turbo he said a lot of the 05 and early 06 have the turbo problem,the one he's going to put in has a small gap between the fin's and the shell so the pressure is realsed that way i guess?but i trust this guy,will see if it works out.
Old Aug 4, 2006 | 07:46 AM
Customz's Avatar
Customz
you're gonna loose a lot of boost doing that. Ford says the rattle is normal. I bet I could make any 6.0 do it. Just ease out of the throttle under high boost conditions to avoid it. Letting off the throttle rapidly gives the boost no where to go (no wastegate) so it escapes past the turbo and flaps the Variable Vanes.
Old Aug 4, 2006 | 09:46 AM
tvsjr's Avatar
tvsjr
Mine does it routinely (bone stock - no tunes for me!) I don't like the noise, but, if it kills a turbo, they can replace it. I've got 3.5 years and 70K miles left before I have to be concerned.
